ej257 swap in wrx....
Results 1 to 7 of 7
    50bhp 3G Impreza htowns_finest's Avatar
    72
    noob question, to build my motor i can just buy a built block and throw it in my 09 wrx???
    i want to do a stock ej257 becuase its forged already and do cams, with some stronger bearings, while using the stock wrx heads,reason for the bearings is becasue i already spun a bearing in my 09,
    so yea its just a simple swap right??? i dont think 1900 for a new block, forged, is bad, well thanks in advance for any help.....
    200bhp 3G WRX nmasse's Avatar
    Jul 2008
    Chicago
    206
    Re: ej257 swap in wrx....
    pretty sure the only difference between the ej255 and ej257 from 2008 and up are the heads on the 257...they have both AVCS on intake and exhaust whereas the 255 only has it on the intake....the pistons are not forged in the Sti motor IIRC....there are posts on nasioc that say the 255 is actually a beter motor for making power (higher compression), but then again the Sti is better suited for power....
    2008 WRB Wagon, AEM CAI, SPT CBE, Tsudo DP, XPT stage 2 tune
    2500bhp Monster chanke4252's Avatar
    Apr 2008
    Indianapolis, IN
    4,657
    I too am under the impression that the pistons in the STI is cast these days. Why not just upgrade internals on the ej255 you already have? Subaru did replace your motor didn't they?
    08 A4 2.0t Quattro 6mt
    09 WRX (sold)
    OGB's Avatar
    Nov 2007
    Chicago
    752
    STi's do not have forged pistons. I'de say go with that block you found and go get some new forged pistons and ARP studs everywhere.
    also... i have a stock '08 WRX block that i need to get rid of.
    "If you're not breakin' shit, you're not goin' fast enough."
    250bhp 3G WRX iceberg2532's Avatar
    Mar 2010
    279
    I know this is an old thread, but I currently ran into a situation where I'm removing my block and am considering swapping an ej257 while I'm at it. since the differences between the 255 and 257 are not complex, should my stock (08) wrx ecu be able to support an ej257 block? Found a shortblock local and will have a professional shop install it, but just want to be sure I'm not gona have to look for an STi ecu while I'm at it ;D
    10bhp 3G Impreza 08scooby's Avatar
    Mar 2010
    there is NO difference between the 255 and 257 block. The sti pistons are NOT forged or cast, they are hypereutectic, so are the 255's. The heads on the 257 are different. they are avcs on both cams (intake and exhaust). your stock wrx computer will not run the exhaust avcs. I would look at the short block packages that places like import image racing offers. just clean up your stock heads and reuse them. also i would not buy the cometic head gaskets either, just get stock ones.
    Both the 255 and 257 have forged rods, but are not strong at all. the 09 and up factory sti cranks are Nitrite treated. you can tell because they are black not silver metal color.
    wrb08wrx's Avatar
    Jul 2008
    prince edward island
    3,401
    i am installe a ej257 stock block as said above zero difference install wise.
    cast piston still so what lots are doing is buying them with a swapped piston set.
    i recommned you contact outfront motorsport through them or vim i got a fully built bottom end rods nitrated crank and mahle piston acl bearings for 2700 so for 800 more a full built motor .
    or get a new sti block with swapped pistons .
    too many mods to list in this box
    so I will list the unmodded parts.
    stock wind shield,taillights ,carpet
  1. EJ257 short block compatible with EJ255 heads?
    By DutchOven in forum Subaru WRX General Aftermarket Talk
    Last Post: 07-10-2011, 08:52 PM
  2. vf 43 swap 08 wrx
    By sptwrx2008 in forum Turbos and Nitrous
    Last Post: 09-01-2010, 10:44 AM
  3. VF40 swap ?'s
    By CJ05 in forum Turbos and Nitrous
    Last Post: 12-07-2009, 11:52 PM
  4. 4EAT to 5MT swap?
    By valin in forum Drivetrain, Transmission and Gear Box
    Last Post: 09-11-2009, 07:23 PM
  5. VF-52 swap complete
    By RobWRBlue in forum Turbos and Nitrous
    Last Post: 05-18-2009, 11:56 PM
00 impreza 08 ej255 swap
08 sti motor swap
ej255 with aftermarket internals
ej257 sti engine into 06 wrx
ej257 swap
ej257 swap wrx
ej257 with 04 wrx trans
sti engine swap
sti factroy shortblock swap
subaru ej257 swap
wrx ej255 ej257 swap
wrx ej257 swap
