Anyone know the part number for the STI mirror signal lights connector?
Someone got a 2011 Service manual ;-)
It looks like they moved the power supply for the windows to that wire. I didn't look much beyond that to compare to the 08-10.
The anti-pinch should stay inside the door, it runs from the motor to the switch, where all the logic lives.
Direct Replacement... Dual Gauge Pod for 2008 - 2013 WRX & STI. Also fits 2009+ Forester. OEM Texture & OEM Color Matched 100%. 52mm gauges ONLY.
sent you a reply email but will post up here for those that may be thinking the same. there is no individual p/n for the connectors off of the harnesses - that would be way too convenient.
just crimp on a 3/16" female quick disconnect. it fits perfectly.
wait a minute, this has nothing to do with the jdm power folding mirror swap...![]()
Hey All,
from Sydney, Australia here, wanted to get the folding mirrors on my MY13 WRX GV
i bought the JDM Switch P/N: 83061SA000 if anyone needs it.
i had a look at the back of my switch connector and i have all pins used from 1 - 9 and pin 10 is the only one unused. i have blinkers on my side mirrors.
no basic options or package with heated nor folding on our mirrors.
didnt get the chance to trace to where it goes, though would i still be able to follow your DIY?
i actually ordered the complete LHS and RHS side mirrors that already come with heated and folding mirror capabilities and painted (still processing order), along with the JDM switch.
i will need to have a look at the connector off the JDM side mirrors to see if it matches the diagrams you guys have.
any help would be great, i will update asap!
thank you.
