killer b oil pan, pickup, and baffle DIY install! - Page 2
Results 11 to 14 of 14
    650bhp 3G STI boostedf4's Avatar
    Apr 2010
    Ohio
    666
    Re: killer b oil pan, pickup, and baffle DIY install!
    Went to try this today, spent about 4 hours trying to get the adhesive to break loose on the pan with no luck, then gave up. Any suggestions?
    Sent from my DROID RAZR using Tapatalk 2
    "As I lay rubber down to street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my ride."
    09 WRX Sedan: Custom Stg 1 tune, custom intake, straight pipe axle back, TiC Super Shifter Kit, Pitch Stop, DIY Solid Trans Mount, Rear Diff/Subframe Inserts
    did you try with a rigid putty knife and/or flat head and pressure, gently of course?
    Apr 2010
    Ohio
    666
    Yep, tried both. Neither work, even tried a hammer with them lol. Its like freaking cement. If worse comes to worse I'll just take it somewhere and let them deal with it haha.
    0bhp 3G Impreza C4pt Insano's Avatar
    Apr 2012
    Bump. I'm planning on doing the pan/pickup/baffle install today is it necessary to unbolt the dipstick to uninstall/reinstall it in the pan? I have a 2011 WRX and I'm pretty sure i have to unbolt the air pump to get to it but i didn't see it mentioned and it looks like its already gone in the pictures. If it is necessary to is it just a few bolts and its out of the way? And other than that I'll just unbolt what the service manual says to and watch the ac lines. Anything else? Thanks ahead of time.
  1. oil pickup necessary?
    By apexone4697 in forum Engine Internals
    Last Post: 06-26-2012, 01:49 PM
  2. Maybe I Need a Pickup Truck
    By greenc51 in forum Anything Under the Sun!
    Last Post: 03-27-2012, 02:55 PM
  3. Oil pickup problems in 3g?
    By gotbeef in forum Engine Internals
    Last Post: 08-24-2010, 09:36 PM
  4. STi killer
    By kik in forum 3G WRX Photo Gallery
    Last Post: 08-07-2008, 07:19 PM
2010 wrx oil pick up.install
2012 wrx oil pan removal
how to change oil pan pickup tube on 06 subaru sti
how to install killer b oil pickup
killer b oil baffle install
killer b oil pan
killer b oil pan install
killer b oil pickup install
killer bee oil pickup
killer bee oil pickup tube install
killer bee pickup tube install
subaru dipstick tube leak
