DIY: Hatch Trim Swap (with plenty of pictures) - Page 2
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 27
    200bhp 3G WRX jmac12's Avatar
    Jul 2008
    State College, PA
    209
    Re: DIY: Hatch Trim Swap (with plenty of pictures)
    Quote Originally Posted by nmasse View Post
    thanks for the help...so if im understanding you correctly, i just need to pick up some weather stripping?
    Yes. I would double check your color matched piece to make sure you don't already have the weatherstripping on it. Another thing I've heard people do is reuse the foam from the old piece, but that seems like a lot more work and you'd have to be lucky enough that the foam doesn't tear and still sticks to the new piece.
    '08 OBP WRX Hatch
    RallyArmor UR Mudflaps, Sport Grille, SPT CBE, Tint & high hopes...
    Super Moderator Courteau's Avatar
    Nov 2007
    Trois-Rivieres, Quebec, Canada
    1,843
    i rather dont put back the foam strip since with the foam strip there was already some bit of rust when i removed the OEM chrome strip... i prefer if the water can leak out easily
    2008 Subaru Impreza WRX 5Doors -5MT - WR Blue Mica - MODDED -
    1998.5 Ford Contour SVT - Toreador Red/Midnight Blue - #5912/6535 - MODDED -
    200bhp 3G WRX nmasse's Avatar
    Jul 2008
    Chicago
    206
    interesting...damned if you damned if you dont i guess...isnt the stripping probably there to protect the hatch switch? as far as the hardware to bolt the damn thing down, are these all reusable bolts or are they the plastic clip things that usually break once u remove them?
    2008 WRB Wagon, AEM CAI, SPT CBE, Tsudo DP, XPT stage 2 tune
    Jul 2008
    State College, PA
    209
    There are 2 philips head plastic clips that you have to remove, but they come off easily. Everything else is either a screw or nut (all reusable). Its really not a hard install. Just a little time comsuming.
    '08 OBP WRX Hatch
    25bhp 3G Impreza hoobidty's Avatar
    Apr 2009
    Seattle/Houston, tx
    36
    I'll be using this thread tomorrow when i paint mine!
    100bhp 3G Impreza ejicon's Avatar
    Apr 2008
    Burbank
    100
    wow.. that's a lot of work just to get that thing off... thanks for doing this.
    yup yup
    50bhp 3G Impreza subyski's Avatar
    Centennial, CO
    51
    Nice write-up. Definitely going to use this when I swap mine out. Thanks.
    2008 Subaru Impreza 2.5i 5-Door SSM
    350bhp 3G WRX Nacron's Avatar
    Sep 2008
    Hawaii
    377
    Swapped mine out and also did my STI wing. Easy peasy.
    2008 Spark Silver Metallic 2.5i Premium Hatch
    17'' Legacy GT Wheels, Splash Guards, K&N Filter, LED Interior Lights, STI Hazard Sitch, Pop Up Arm Rest, LED Rear Turn Signals, LED License Plate Lights, Kakumei CF Door Pillars, Legacy Center Console, GT Shift Surround, Pedobear
  10. #19
    500bhp 3G STI Zombie's Avatar
    Jan 2008
    Canada
    537
    Quote Originally Posted by Courteau View Post
    I just got my trim peace from SGP, I was inspecting the area and I see rust popping out the top of the trim just above the emblem.
    What is rusting under there and should I get it looked at by subaru? I don't want to replace the trim, then find out that some body work needs to be done and Subaru blame me for the rust.
  11. #20
    350bhp 3G WRX Ogden's Avatar
    Boston, MA
    389
    And viola!
    Thanks for the instructions, total time was probably 1/2 hour to 45 min. For the planged bolts on the tail light, I used a screwdriver type tool that came with my socket set and took the 8mm socket. For the flanged bolts that held the trim on, I used the driver on the middle two. for the outer two, I loosened them with the socket but them just took them off by hand.
    Awesome write-up. Thanks again!
    Journal:
    MySubie.com:
  1. FS: 08+ Chrome Hatch Trim
    By NH8991 in forum Want to Sell
    Last Post: 02-09-2011, 07:15 PM
  2. WTB: Rear Hatch TRIM
    By bobola in forum Want to Buy
    Last Post: 08-28-2009, 10:28 PM
  3. hatch chrome trim fixes (pictures please)
    By blackened in forum 3G WRX Photo Gallery
    Last Post: 09-16-2008, 12:11 AM
  4. Hatch Trim Removal
    By hwaang in forum Subaru WRX Do It Yourself Help
    Last Post: 05-09-2008, 01:41 PM
08 wrx hatch trim
chrome trim for 08 impreza
diy hatch trim swap wrx
how to remove 08 wrx rear filler panel
how to remove subaru impreza hatch trim
how to remove the rear tail lights and chrome trim from a 2008 subaru impreza hatch back
impreza hatch chrome trim
impreza rear hatch trim 2008 removal
removing hatch trim 2002 impreza ts
subaru impreza wrx wagon liftgate interior panel
subaru rear hatch interior clips
wrx hatch trim
