Is there a faster steering rack for the 3G? - Page 2
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 28
    Re: Is there a faster steering rack for the 3G?
    Quote Originally Posted by Dartholomew View Post
    if it was just a matter of disabling VDC, I'd be there in a heartbeat.
    exactly...me too man, me too!
    200bhp 3G WRX 2010 WRX Limited's Avatar
    Mar 2010
    Vancouver
    247
    Oh man, this is bad news. I always had it in my head that I would upgrade my steering rack and now it's leaking. So I have to replace it with a stock one? bummer.
    AEM Meth Injection, Fast Motorsport FMIC, Grimmspeed EBCS, AEM Cold Air Intake, Invidia Catless Downpipe, Invidia Q300 exhaust, NGK 1 step colder Iridiums, DeatschWerks DW65c fuel pump, BC Racing BR Coilovers, Crawford Performance CF Wing, Gold Rota G-Force 18 x 8 1/2, AEM Gauges
    10bhp 3G Impreza kalidas's Avatar
    Apr 2009
    20
    Quote Originally Posted by 2010 WRX Limited View Post
    I agree. My rack just started leaking also. I figured I would just upgrade to something better. Unfortunately it looks like our only current option is stock replacement. I haven't even been able to find any information about someone swapping an STI rack into a WRX.
    Mar 2010
    Vancouver
    247
    So I tried to source a new rack and there are no aftermarket available that I can find. My local dealership wants $1100 for a new one I hope there is a rebuild kit or something available cheaper than that!!
    Quote Originally Posted by kalidas View Post
    why would you want to swap an STI rack (same ratio) into a WRX?
    So I tried to source a new rack and there are no aftermarket available that I can find. My local dealership wants 00 for a new one!! I hope there is a rebuild kit or something available cheaper than that!!
    why are you looking to a source a new one? you can get one from a salvage much cheaper than that, sir. or just buy one from tibor; sometimes he has one or two cores.
    200bhp 3G WRX coogs's Avatar
    Jan 2010
    214
    8
    How and why did it leak?
    process west
    invidia
    AVO
    eibach
    koni
    deautshwerks
    2500bhp Monster 06f250sd's Avatar
    Orange County, CA
    3,807
    42 times
    So I tried to source a new rack and there are no aftermarket available that I can find. My local dealership wants 00 for a new one I hope there is a rebuild kit or something available cheaper than that!!
    We send the racks out for repair all the time, just depends on what is wrong with yours.
    Apr 2009
    20
    Quote Originally Posted by monkiboy View Post
    I may have been mistaken but I thought that the ratio on the 09 wrx was 16.5:1 and the sti was around 15:1. Also I was under the impression that the input shaft for the sti would "feel" more responsive due to the fact that it uses more of a solid shaft with a u-joint whereas the wrx has a rubber dampener for the joint in the input shaft. I probably just missed it in a search but I was not able to find a definitive answer as to whether or not they were a direct swap between the wrx and sti.
    My steering rack just started leaking from the valve area where the input shaft mates with the steering rack. I checked to make sure all of the bolts and hydraulic lines were tight around that area, at least all of the ones I could get to without removal, and everything seemed fine. My guess is that a seal or an o-ring failed and I need to swap it out.
    Not that it's necessary but I figured since I was going to replace it I would check to see if there was an upgrade over the stock.
  10. #19
    it is a direct swap. check out power6 thread. he did the sti input shaft swap and found neglible feedback increase/benefit.
  11. #20
    Apr 2009
    20
    Ok, I must have just missed it. I will skip that then. I will just look for a salvaged one or get a remaned wrx rack
  1. FS: BNIB 08+wrx/sti Whiteline steering rack bushings
    By hiprsha666 in forum Want to Sell
    Last Post: 12-04-2011, 06:54 PM
  2. steering rack bushing help
    By Turbospeed in forum Subaru WRX General Aftermarket Talk
    Last Post: 03-30-2011, 03:29 PM
  3. Racecomp steering rack bushings
    By joneSi in forum Subaru WRX Suspension
    Last Post: 01-13-2011, 06:19 PM
  4. Whiteline steering rack bushing issues?
    By gotbeef in forum Subaru WRX Suspension
    Last Post: 01-05-2010, 12:24 PM
  5. Any feedback on Whiteline steering rack bushings?
    By DougM in forum Subaru WRX Suspension
    Last Post: 07-06-2008, 01:52 AM
how to calculate 29 turns lock to lock in steering pdf
steering rack
wrx steering rack leaking around input shaft
