Those would definitely fit. How much do they weigh? I didn't see on their website.
Anyone try these on a 2008 - 2010 WRX? I am considering them for my 2009 wrx hatchback, but would like to hear how much work is required (for 245's or 255's).
Sure would make for some nice, light, high-quality wheels at a reasonable price:
http://949racing.com/17x9-6ULR-Tungsten.aspx
looks nice. im currently rocking 245s on my 08
installed: rallitek 22mm rear sway and 25 mm front sway, rallitek front and rear end links,BC coilovers, rota g-forces powder coated white, AVO 380 turbo, CAI, 255 fuel pump, 850 cc injectors, AVO FMIC, TXS TBE, ERZ DP, light crank pulley, tuned at 375 wph and 431 ftq
I'd be cautious with inner strut clearance with them.
Not saying they won't fit (I had been hoping to run 18x8.5 +48), I just know it'll be pretty close depending on tires and stuff.
-- Jeremy
09' WRX
Sportwagen zum einbauen!
I really doubt those will fit with a proper tire. Some guys had issues with a 17x9 +45...the tire was hitting the coil. Maybe if you run close to no camber they might work. But if that's the case I'd rather run a narrower wheel and a healthy dose of camber for performance.
2009 WRX Sedan | Forman Custom Rotated GTX3076R Kit | Gruppe-S EL Header | TiAL 44mm EWG | Reversed STI Manifold | Invidia CBE | Perrin FMIC | Aquamist HFS-3 | Tarmac2 Coils | Stoptech 328x28mm BBK | Rota Grids 18x8.5 | 255/35/18 Star Specs | Whiteline 24/22 | Carputer | N-1 CS Lip |
That brings up a good point...are you running coilovers? If so, I can't imagine you will have a clearance issue. If you are running stock suspension, or something upgraded (GTWorx, Koni, etc) then you might have a clearance issue.
Tell DutchOven that...he had the +45 on BC coils...his tire was hitting the coil
Really? Wow, I have +42's with 245's and I don't even come close to having an issue.
Yeah I don't know...dur4ce and I had a discussion about some setups and I wasn't really feeling the 6ULRs...I'll probably end up with a +42 DPT
