Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
    900bhp 3G STI xluben's Avatar
    Oct 2010
    Minneapolis, MN
    940
    3
    2011 WRX Stock vs. Stage 1 vs. Stage 2
    I finally was able to install my COBB downpipe and get my 2011 WRX retuned. Baseline, Stage 1 and Stage 2 information is included. Stage 1 tune was done with the SPT cat back already installed. Only change since then was adding the downpipe. Tuning was done on 16" steelies and winter tires (just like the baseline and Stage 1 tune). RomRaider log was used to create the dyno plot using Virtual Dyno. I set CF=1, which makes the Virtual Dyno read similar to COBB's dyno (LINK).
    I am really happy with the tune. Nuke kept it conservative enough that I shouldn't have to worry about my car, but still made it much, much quicker than Stage 1. The mid range pull is great! Nice big torque numbers from 3k and up. Car feels so much stronger now. The COBB downpipe also makes it sound a bit meaner.
    Feel free to discuss!
    Event: Stage 2 Road Tune
    Ambient Temp: 20F
    Elevation: 725ft
    Weather: Cloudy
    Road Conditions: Flat
    Tires: General Altimax Artic 215/55R16
    Car: 2011 WRX 5 Door
    Tuner: Nuke
    Dyno Info: Virtual Dyno - CF=1, Smoothing=5
    Transmission: Stock 5 Speed
    Gear: 3rd
    Target Boost: 18.5psi
    Target AFR: Unknown
    Fuel: 93 Octane Unleaded
    Engine/Power Modifications: SPT Cat Back Exhaust, COBB Downpipe
    Driveline Modifications: None
    Suspension Modifications: None
    Other Modifications: 16" Steel Wheels
    Baseline:
    Peak HP at RPM: 239hp@6,000rpm
    Peak Torque at RPM: 259lbft@3,200rpm
    Stage 1:
    Peak HP at RPM: 251hp@6,000rpm
    Peak Torque at RPM: 294lbft@3,400rpm
    Stage 2:
    Peak HP at RPM: 298hp@6,100rpm
    Peak Torque at RPM: 342lbft@3,500rpm
    | 2011 WRX | 5 Door | Black | Built Motor | Rotated PTE 6266 Turbo | STI 6 Speed |
    greenc51's Avatar
    Atlanta, GA
    2,598
    Re: 2011 WRX Stock vs. Stage 1 vs. Stage 2
    nice steelies man. i did that to my ex's eclipse for winter mode.
    nice numbers too! 8)
    2008 DGM WRX Sedan - SGP Optional Front Lip - Magnaflow CBE - VF-52 - TP Stage 2.52 - Progress Springs - Koni Struts - Perrin F/R Sways - Perrin Panel Filter - WeatherTech - Perrin 1-Piece DP - Torque Solutions Pitch Stop - Rota DPT 17x9 - 245/40 Sumitomo HTRZ III - StopTech SS Lines & Pads
    2500bhp Monster TougeMonster's Avatar
    3,478
    The steelies look very nice. Very conservative tune but I like the plot. Most people would ask me to get highest average hp out of the tune which would result in more of a bell shape and flatter curve with as much power coming on earlier as possible. You have a plot similar to my personal STi. Good approach, easy to drive at WOT.
    Here is a sample (not one of mine) of what most people tell me to do:
    "It doesn't matter if your car is the fastest on the race-track. It's a different story on the streets, your car has to be fun, fast, and safe in any road condition." --- Keiichi Tsuchiya
  4. #4
    2000bhp Monster Turbospeed's Avatar
    Sep 2010
    Edmonton, AB
    2,179
    10 times
    Nice numbers, car sounds amazing btw!
    TP stage1 - AEM CAI - Cobb CBE - Whiteline sways - Kartboy Endlinks - SS - GS MCB - GS HS - Whiteline Bushing Catalog - Group N Pitch Stop - Group N Trans mount - Rally Armour UR - Tint
  5. #5
    Oct 2010
    Minneapolis, MN
    940
    3
    Quote Originally Posted by greenc51 View Post
    Thanks. Steelies work great for me. Had them on my last car for winter tires as well. Easy/free to swap each season, and I think they look pretty good on a black car
    Quote Originally Posted by TougeMonster View Post
    http://i806.photobucket.com/albums/y...comperison.jpg
    Basically to peak the torque sooner, and then have it drop off more quickly? That's the only way I could see the hp curve flattening out. The plot you posted has the torque curve peaking at a higher RPM than my car, and it dies off sooner, not what I would want. Power delivery from this tune is smoother and strong up to the top, very nice for daily use. I'm really happy with how it feels around town and on the highways.
    Quote Originally Posted by Turbospeed View Post
    Thanks!
  6. #6
    3,478
    Quote Originally Posted by xluben View Post
    As stated, your tune is nicer to daily but lots of people do the bragging rights deal. The tune posted was from P&L and just a sample of curvature. Your tq graphs are actually pretty similar if you scale them.
    The biggest difference would be that the pic posted was a stage 1, with no mods added but a tune. At stage 2, the numbers would be well past your own with much higher peaks and boost coming on sooner.
    Just to show you your conservative/linear approach against a peak power approach
    P&L stage 1 gains were 35whp and 75wtq against your stage 2 35whp 55wtq gains
  7. #7
    Oct 2010
    Minneapolis, MN
    940
    3
    Ah, that makes sense. I'd be curious to see the boost, AFR, and timing for that tune.
    The torque curve for the baseline run looks a bit off to me. Pretty much flat with the peak at 4.5k
    I do agree that that Stage 1 shows about as much gain as my Stage 2. I'm OK with a conservative tune, still is lots of fun!
  8. #8
    900bhp 3G STI ofspunk7's Avatar
    Sep 2009
    The Flat Four-est
    940
    Did nuke talk to you about switching to E85? He did my E85 tune and man, i am happy i switched over.
    09' WRX Base DMG ~ E85 NF Tune @ 23PSI 350WHP/360WTQ ~ Rota Grids 18x9.5 w/ Star Specs ~ Invidia Q300 Quad Tip ~ IPR TMIC ~ Forge BPV ~ GrimmSpeed Electronic Boost Controller ~ GrimmSpeed Master Cylinder Brace ~ GrimmSpeed Lightened Pulley ~ Walbro Fuel Pump ~ 930cc NF Modified Injectors ~ TurboXS Stealthback DownPipe ~ Mode Dual Adj SS ~ Whiteline Sways 24F/22R ~ RalliTek HD Endlinks ~ K&N Drop In Filter ~ DDM Lows & Fogs ~ Hellas ~ GrimmSpeed Tow Hook License Plate ~ Hawk HP+
  9. #9
    3,478
    It would be similar to yours actually but applied at stage 1 as opposed to with stage 2 hardware. 18-19 psi 10-11afrs at boost with some advanced timing. However, this just means that it is running higher WGD to compensate and probably a bit more fuel to cool because of restriction from the DP not letting the gas out fast enough. Yours is definitely better for the long run.
    If it was stage 2 they bump up to about 22-23psi on STi and to about 20-21 on the WRX just because of the WRX IC. This shifts the curve up to show gains of about 100whp and 120wtq against stock which IMO is pretty damn aggressive.
    I prefer your approach
    Here are AMR numbers for reference (aggressive?)
    Numbers
    Dyno: Dyno Dynamics (1.0CF)
    Tuner: AMR
    Wheel HP: 325whp (stock: 215whp)
    Wheel TQ: 340wtq (stock: 225wtq)
  10. #10
    Oct 2010
    Minneapolis, MN
    940
    3
    Quote Originally Posted by ofspunk7 View Post
    Yeah, he mentioned you by screen name He had brought it up when he did my Stage 1 tune and I hadn't even thought about it at the time. Since then I've been looking up more about it and I am strongly considering it (and supporting mods) for sometime this summer.
    We should meet up sometime so I can see what to expect
    Yikes, that definitely doesn't sound like what I want. Those Stage 2 numbers sound pretty crazy. I'd be curious to see how long those cars last... I'll wait until I have some more mods (TMIC, BPV, Fuel Pump, and Injectors are planned for an E85 tune).
    Nuke does a good job of talking sense into me while tuning (I'm sure I could be convinced into getting an aggressive tune, but I'd probably regret it later). He doesn't want to see brand new cars blown up any more than the owners. He doesn't even use the Virtual Dyno program to tune for big numbers. In fact the logs don't get loaded into it until he is done, and that's only because I like looking at graphs
Ads
  1. 2011 WRX TP Stage 1 Log
    By kiota in forum Tuning Fork
    Last Post: 05-13-2012, 02:04 PM
  2. 2011 WRX Stage 2 + E85
    By xluben in forum 3G WRX Dyno
    Last Post: 10-25-2011, 10:20 PM
  3. Stock,TP Stage 1 and TP Stage 2 Dyno Graph
    By 09wrxrocket in forum 3G WRX Dyno
    Last Post: 09-11-2011, 06:47 PM
  4. 2011 WRX Sedan Stock vs TP Stage 1 - Virtual Dyno
    By masayver in forum 3G WRX Dyno
    Last Post: 07-13-2011, 07:15 PM
2011 stage 2 wrx dyno
2011 wrx cobb stage 2
2011 wrx cobb stage 2 dyno
2011 wrx downpipe
2011 wrx stage 1 hp
2011 wrx stage 2
2011 wrx stage 2 dyno
2012 wrx stage 1 vs stage 2
cobb stage 1 wrx hp
cobb stage 2 2011 wrx
stage 2 2011 wrx
