Help install Pioneer avh-P2300 dvd player green wire
Results 1 to 10 of 19
    300bhp 3G WRX jimmytt01's Avatar
    Jan 2010
    PA
    309
    hey i thought you hook up the dvd parking brake wires to negative? In the instructions it says power supply?? I dont want to fry the unit so asking radio gurus.
    Page 65 of the PDF.
    Thanks..Jim
    Attached Images Attached Images
    2008 Wrx Sedan-Obsidian Black Pearl Metallic
    TP Stage 2-Perrin DP-Perrin filter-GTSpec bars-Drag DR31-Q300-SMY Cluster
    08subiewrx's Avatar
    Jun 2008
    Woodbury , New Jersey
    2,678
    8 times
    Re: Help install Pioneer avh-P2300 dvd player green wire
    I think this wire is for safety purposes... You are not supposed to play dvd's, or the navagation system while driving so certain functions will only be available with the parking brake applied. If it was me installing it personally... I would connect that wire to a ignition + wire to have full function of the unit at all times.
    08 Wrb Wrx - Bone Stock! - Sold
    - Bought a house
    A Pillar pods for sale!!!!----->
    Miata Build --->
    Jan 2010
    PA
    309
    Yea like I said I am concerned hooking it up to power and damaging the unit.
    08subiewrx's Avatar
    Jun 2008
    2,678
    8 times
    Quote Originally Posted by jimmytt01 View Post
    It says to hook it up to the power side of the parking brake wire so you are fine
    - Bought a house
    Miata Build --->
    Jan 2010
    PA
    309
    Well I hooked it up to a power wire and still nothing. So I finally tested it out and it seems it needs to cycle through a power off power to work. So hooked it up to the ebrake and it works. If I turn the car on with the brake on I need to let it down the pull it back up and it will work.
    10bhp 3G Impreza abxx49's Avatar
    Apr 2011
    23
    Watch this:
    clamsjager's Avatar
    Feb 2008
    Waterford, Ct
    5,666
    17
    if i remember right i hooked mine to the acc power and it lets me play videos while driving.
    2015 DGM WRX Limited..... cars not even here and the mod list is to long to list.
    08subiewrx's Avatar
    Jun 2008
    2,678
    8 times
    Quote Originally Posted by clamsjager View Post
    Thats what I was thinking lol
    - Bought a house
    Miata Build --->
    Super Moderator Courteau's Avatar
    Nov 2007
    Trois-Rivieres, Quebec, Canada
    1,843
    the relay is the best trick.
    2008 Subaru Impreza WRX 5Doors -5MT - WR Blue Mica - MODDED -
    1998.5 Ford Contour SVT - Toreador Red/Midnight Blue - #5912/6535 - MODDED -
    350bhp 3G WRX LEXtoWRX's Avatar
    388
    I installed one yesterday in a 2005 f150. We just wired it to a switch and the other side of the switch went to a ground. You can't give that wire a constant ground or you won't be able to watch movies. So eevery time he turns his truck on he has to turn the switch completing the "ground" circuit. If he left it that way the next time he turns the truck on he will have to operate the switch like this (on, off, on) basically opening the circuit then closing it again. If you have any questions pm me and maybe I can explain it better.
    Check out my build thread---
  1. How To: Wire and install a Subwoofer to stock head unit! (danger to 56k)
    By clamsjager in forum Subaru WRX Do It Yourself Help
    Last Post: 07-19-2012, 09:17 PM
  2. Metra Double Din install kit with wire harness $25 shipped
    By 2011wrxhatch in forum Want to Sell
    Last Post: 02-13-2011, 08:13 PM
  3. Pioneer AVIC-D3 Install
    By 08BlackWRX in forum 3G WRX Electronics
    Last Post: 05-08-2010, 04:16 PM
  4. i have a stock cd player and ac unit for an 08
    By thegonz in forum Want to Sell
    Last Post: 12-07-2008, 09:26 PM
avh p2300 wiring
avh p2300dvd wiring diagram
dvd green wire ground
how do i defeat parking brake wire on pioneer dvd player
how to install pioneer avh-p2300
how to set up pioneer avh green wire
media player dvd green wire ground
pioneer avh p2300 dvd not powering up
pioneer avh p2300dvd wiring diagram
pioneer avh-p2300dvd wiring diagram
pioneer radio light green wire
what is the light green wire on back of pioneer avh-p2300dvd
