Installs, service, maintanance, repairs, custom work! In So Cal.
Page 1 of 100 1 2 3 11 51 ... LastLast
Results 1 to 10 of 998
    Premium Sponsors
    InfamousPerformance.net's Avatar
    Feb 2011
    Escondido, California
    7,458
    Shop located in Escondido. Full fabrication services available. Specializing in Subarus. No job too big or small.
    Address is:
    1948 Don Lee Place, Suite 8
    Escondido, CA 92029
    Check us out of Facebook:
    https://www.facebook.com/pages/Infam...6553829?ref=hl
    Check us out on Yelp:
    http://www.yelp.com/biz/infamous-per...ning-escondido
    Phone: 760-781-1126
    email: sales@infamousperformance.net
    Please call for appointments.
    For custom work we charge $100 per hour plus materials. For standard things we will quote a price.
    Some basics we get lots of request for;
    Exhaust Install Pricing (Labor)
    Headers $175
    Headers Back (Headers, Uppipe, Downpipe, Axleback) $450
    Headers & Uppipe (Headers, Uppipe & Downpipe Only) $425
    Uppipe (Uppipe, Downpipe) $350
    Uppipe Back (Uppipe, Downpipe, Midpipe & Axleback) $450
    Downpipe Back (Downpipe, Midpipe & Axleback) $250
    Downpipe (Downpipe) $200
    Catback/Axleback $75
    Hardened Exhaust Hangers $75
    *Prices based on stock vehicles in good working condition and standard replacement parts (no major rust, broken bolts, etc) Non-Standard installs will be billed at our regular hourly rate.
    Turbo Install Pricing (Labor)
    Turbo/Injectors/Fuel Pump (W/No Air Pump and Side Feed Injectors) $800
    Turbo/Injectors/Fuel Pump (W/Air Pump and Top Feed Injectors) $900
    Turbo (Bolt in) $400
    Injectors (W/No Air Pump and Side Feed Injectors) $300
    Injectors (W/Air Pump and Top Feed Injectors) $400
    Fuel Pump $100-125
    Mounts & Bushings Install Pricing (Labor Only)
    Motor Mounts $200
    Transmission Mount $100
    Anti-Lift Kit $225
    Front Lower Control Arm Rear Bushings (Legacy '05+, Impreza '08+) $225
    Front Lower Control Arm Inner & Rear Bushings (Legacy '05+, Impreza '08+) $225
    Front Roll Center Kit (Legacy '05+, Impreza '08+) $175
    Front LCA Bushings & Roll Center Kit (Legacy '05+, Impreza '08+) $350
    Steering Rack Bushings $200
    Rear Subframe Bushings $150
    Rear Differential Locking Bolts $100
    Rear Differential Mount Bushings $200
    Short Shifter (5MT) $100
    Short Shifter (6MT) $175
    Short Shifter w/Bushings (5MT) $150
    Short Shifter w/Bushings (6MT) $205
    *Prices based on stock vehicles in good working condition (no major rust, broken bolts, etc)
    Electronics Install Pricing
    Electronic Boost Gauge $200
    EGT Gauge $225
    A/F Gauge $200
    Oil Pressure/Temp Gauge (In Block, only avail on certain models) $200
    Oil Pressure/Temp Gauge (Filter Style) $175
    Electronic Boost Controller Grimmspeed Style $75
    Hella Horns $200
    Hella Horns(Bumper Removal Required) $250
    Services Included in our 30K Mile Service
    Replacement of:
    Coolant (Subaru Long Life) (Coolant Conditioner added on NA Cars)
    Brake Fluid (Full Flush with ATE Type 200 or Standard Fluid)
    Transmission Fluid (Subaru HP or Subaru ATF)
    Front and Rear Diffy Fluid (Subaru HP)
    Oil Change (Motul 8100 X-clean, Conventional – Subaru Filter)
    Fuel Filter (if applicable)
    Air Filter
    Rotate Tires
    NGK Spark Plugs (Non-Turbo Cars)
    ACC Belts (Except H6 and 08+ WRX)
    Clutch Fluid
    Checks on: Brakes, Parking brake, Clutch, Suspension, Fuel lines, Exhaust
    Pricing:
    Turbo
    30k Using Conventional Engine Oil & Subaru Oil Filter $485
    30k Using Motul 8100 X-clean Engine Oil & Subaru Oil Filter $530
    *On 09+ Impreza/Legacy (and cars with Subaru Super Long Life Coolant) $50 discount due to the coolant change interval being 100k miles.
    Non-Turbo – H6 add $70 (serpentine belt, oil)
    30k Using Conventional Engine Oil & Subaru Oil Filter $440
    30k Using Motul 8100 X-clean Engine Oil & Subaru Oil Filter $475
    *On Automatic Transmission Cars, we will do a drain and fill of the fluid and replace the ATF Filter (Spin on Type), cost for AT cars is $45 Extra due to Fluid and Filter costs.
    **On Forester $20 extra due to plug placement.
    Services Included in our 60K Mile Service
    Replacement of:
    Air Filter
    Rotate Tires
    NGK Spark Plugs
    Clutch Fluid
    Pricing:
    Non-Turbo Engines – H6 add $70 (serpentine belt, oil)
    60k Using Conventional Engine Oil & Subaru Oil Filter $525
    60k Using Motul 8100 X-clean Engine Oil & Subaru Oil Filter $570
    Turbo H4
    60k Using Conventional Engine Oil & Subaru Oil Filter $600
    60k Using Motul 8100 X-clean Engine Oil & Subaru Oil Filter $650
    *On Automatic Transmission Cars, we will do a drain and fill of the fluid and replace the ATF Filter (Spin on Filter Type), cost for AT cars is $45 Extra due to Fluid and Filter costs.
    ***On H6 Models $35 extra due to plug placement and quantity.
    Services Included in our 90k Mile Service
    Replacement of:
    Air Filter
    Rotate Tires
    Clutch Fluid
    Pricing:
    Turbo
    90k Using Conventional Engine Oil & Subaru Oil Filter $485
    90k Using Motul 8100 X-clean Engine Oil & Subaru Oil Filter $530
    90k Using Conventional Engine Oil & Subaru Oil Filter $440
    90k Using Motul 8100 X-clean Engine Oil & Subaru Oil Filter $475
    Services Included in our Timing Belt Service
    Replacement of:
    Timing Belt
    Timing Belt Tensioner
    Timing Belt Pulleys
    Water Pump
    Thermostat
    Coolant Flush
    Timing Belt Service Pricing:
    Turbo
    Timing Belt Service $775
    Timing Belt Service (when combined with a 90k service) $725
    Non-Turbo
    Timing Belt Service $745
    Timing Belt Service (when combined with a 90k service) $695
    Oil Changes
    Motul 8100 X-clean 5w30 w/Subaru Oil Filter $90
    Standard Conventional Oil 5w30 w/Oil Filter $50
    Bring your own Oil/Filter Change $40
    Coolant Changes
    Subaru Long Life Coolant Drain/Fill $125
    Subaru Super Long Life Coolant Drain/Fill (100k Blue Subaru Fluid) $165
    Gear & Transmission Changes (labor only)
    Subaru 5MT Front Diff, Trans - Subaru HP $75
    Subaru 6MT Front Diff, Trans - Subaru HP $85
    Add Rear Diff $35
    Subaru 4EAT or 5EAT ATF - Subaru ATF $80
    Add Front and Rear Diff $70
    Add Subaru ATF Spin on Filter $10-50
    BRZ/FRS 6MT Trans – Subaru HP $75
    BRZ/FRS Rear Diff $45
    5MT/6MT Clutch Labor
    Clutch & Flywheel Labor Only $550
    Add Front Diff, Trans – Subaru HP $75
    5MT Flywheel resurface (single mass) $90
    6MT Flywheel resurface $70
    Misc Services (labor only)
    AC/Alt-PS Belts (Per Belt except 08+ WRX AC) $30
    Spark Plug Replacement – Turbo (4) add $25 for OBXT/Forester $200
    Compression Test – Turbo (4) add $25 for OBXT/For $235
    Compression Test – Non Turbo (4) $150
    Spark Plug Replacement – Non Turbo (4) $100
    Springs/Shocks/Struts
    Springs/Struts/Shocks (Labor Only) $300
    Koni Sport Struts Inserts (Labor Only) $400
    Coil Over Install and ride height set $400
    CV Joints/Axles/Wheel Bearings
    Drive Axle w/CV Joint (Labor Only) $100
    Sway Bars
    Rear Sway Bar w/o Mounts (Labor Only) $100
    Front Sway Bar (Impreza '02+, Legacy '05-'09) $100
    Standard Engine Rebuilds
    CP Forged Pistons w/Rings
    King Bearings Rods
    King Bearings Main
    ARP head studs
    11mm Sti oil pump
    Timing kit w/water pump
    OEM Gasket Kit
    Bore/Hone w/torque plates
    3 angle valve job, adjustment, resurface, cleaning of heads
    Service intake AVCS gears
    OEM PCV assembly
    OEM T-stat
    NGK plugs
    OEM Coolant
    Oil (10 qts Motul Break in oil)
    2 x OEM Oil Filter
    Labor
    $6400
    Brakes
    Standard Fluid Flush (labor only) $70
    ATE Type 200 Fluid Flush $125
    ATE Fluid Flush + Stainless Steel Line install (02-07 Impreza) $225
    ATE Fluid Flush + Stainless Steel Line install (08+ Impreza) $250
    ATE Fluid Flush + Stainless Steel Line install (05-09 Legacy) $300
    Front or Rear Pads Installed $100
    Front and Rear Pads Installed $170 w/fluid flush (labor only) $220
    Front Rotors and Pads Installed $200
    Front and Rear Rotors and Pads $300 w/fluid flush (labor only) $350
    Coolant Related Items
    Radiator Replacement (Labor) $200
    Accessory Related Items
    Alternator (Labor Only) $100
    Misc Items
    Subaru Valve Cover Gaskets (Labor both sides) $400
    Subaru Head Gaskets Non-Turbo SOHC Engines (Parts & Labor Estimate) ~$2,500
    Subaru Head Gaskets DOHC Engines (Parts & Labor Estimate) ~$3,800
    (If the Heads need reconditioning additional charges may apply)
    Parking Brake Adjustment $50
    Prices valid on stock vehicles in good working condition (no major rust, broken bolts, etc). Prices are labor only, materials extra (unless otherwise noted).
    Premium Sponsors
    Feb 2011
    7,458
    Re: Installs, service, maintanance, repairs, custom work! In So Cal.
    Tax Season Sale!!! Use promo code "April14" at checkout for 10% off during the entire month of April.
    The Koni Shock Value Sale is going on until May 31st. Take 25% off all Koni yellow shocks!!! No promo code required. Free shipping on orders over $299 too!
    April14 Promo code can not be combined with any other offers and is not valid on Subaru OEM parts.
    2014 Presidents Day Sale!!!
    10% off all orders using promo code "Pres14" at checkout! Free shipping on all orders $299+ too!
    Sale and promo code valid from 2/17/14-2/28/14.
    No order minimum. No limit to times the code can be used.
    clamsjager's Avatar
    Feb 2008
    Waterford, Ct
    5,666
    17
    takes you guys two hours for a downpipe and three for an up pipe?
    2015 DGM WRX Limited..... cars not even here and the mod list is to long to list.
    Quote Originally Posted by clamsjager View Post
    he hasn't listed hours. he says above it's fifty dollars per hour for custom work. the prices indicated for those two installs you mention, are his labor prices for standard/commonly completed work.
    clamsjager's Avatar
    Feb 2008
    Waterford, Ct
    5,666
    17
    ohh well you would think normal labor would be cheaper than custom labor then. Trying to figurte out how much time to allot for install
    i dont know how it works out but if their labor rate is 50/hour or less than that, that'd be ridiculous. i know we have it pretty average on the east coast with $79-90/hour so their prices are definitely more than fair.
    in trying to figure out how much time to put aside, ask a shop how long it takes them and then add an hour or two for seized bolts, lack of the "right tool", lack of knowledge, and just for good 'ol swearing for a minute or two, haha.
    clamsjager's Avatar
    Feb 2008
    Waterford, Ct
    5,666
    17
    trying to decide when i get a new turbo if i want a shop to install the goods or if ill just suffer with jackstands in the garage.
    Premium Sponsors
    Feb 2011
    7,458
    Prices quoted are for standard jobs. Time varies. Usually depends on mods.
    $50 per hour for custom work is a "promotional" rate. Normal charge is $75-$95 per hour.
    If trying to budget time, please send a PM, email or call.
    We specialize in Subies and are more than familiar with them. We have all the proper tools and parts. I have 4 Subies of my own in my stable. 2005 LGT wagon 5MT, 2008 LGT SpecB, 2008 LGT 5EAT, 2002 WRX.
    We offer aftermarket parts and accessories as well as the full OEM catalog. Tuning is also available via e-tune and road tune.
    Premium Sponsors
    Feb 2011
    7,458
    We offer installation and tuning for everything we sell.
    Premium Sponsors
    Feb 2011
    7,458
    Appointments available.
  1. Installs, service, maintanance, repairs, custom work! In So Cal.
    By InfamousPerformance.net in forum Infamous Performance & Tuning
    Last Post: 02-28-2014, 11:28 AM
  2. 7,500 maintanance 2011 wrx
    By musclemilk in forum Subaru WRX Newbie Support
    Last Post: 10-21-2011, 02:21 PM
  3. Replies: 3
    Last Post: 10-15-2011, 09:32 AM
  4. Supertones and some custom grill work (pics!)
    By Troa in forum 3G WRX Photo Gallery
    Last Post: 03-26-2009, 03:20 PM
  5. My custom fabrication work --- Many pics!
    By wjc04wrx in forum 3G WRX Electronics
    Last Post: 11-03-2008, 06:53 PM
30k mile service 2011 wrx
great morning quotes and pics
infamousperformance.net e-mail
