Top vs Side feed injectors
Results 1 to 10 of 16
    250bhp 3G WRX mitchkeller87's Avatar
    Jan 2011
    North Dakota
    290
    I see that most everyone has top feed inhectors when they upgrade there turbo, so my question is what is the main difference beween top and side feed? I know we have side feed now, why cant I buy bigger side feed and have the same gains as top feed?
    Built Motor, GT35r, 500whp when I ran out of fuel.
    2500bhp Monster chongl's Avatar
    Socal
    3,790
    Re: Top vs Side feed injectors
    We have topfeeds. The pre-07 STIs have sidefeed
    2009 WRX Sedan | Forman Custom Rotated GTX3076R Kit | Gruppe-S EL Header | TiAL 44mm EWG | Reversed STI Manifold | Invidia CBE | Perrin FMIC | Aquamist HFS-3 | Tarmac2 Coils | Stoptech 328x28mm BBK | Rota Grids 18x8.5 | 255/35/18 Star Specs | Whiteline 24/22 | Carputer | N-1 CS Lip |
    Jan 2011
    North Dakota
    290
    so since I bought a bigger turbo and a front mount do I just need to buy a bigger set of top feeds to supply the extra fuel? Or do I need new fuel rails and new injectors?
    2500bhp Monster GravyRobber's Avatar
    Kalamazoo, MI
    3,756
    Just bigger top feeds and a fuel pump will be just fine. What turbo did you buy?
    Socal
    3,790
    And to be completely honest, if you are asking these types of questions, it would be BEST if you do some more research and educate yourself first. There's a lot more than just throwing on a bigger turbo...lots of things can pop up that you don't anticipate and realize.
    Just throwing that out there.
    Jan 2011
    North Dakota
    290
    I bought a td06 20g, I am gonna take it down to minneapolis to Modern Automotive Performance to get a tune after I install it and get my intercooler, injectors, and fuel pump in.
    And chongl isnt the point of having a forum is to get answers and ask questions? I did research before I asked it here but people from other sites all say wrx are side feeds and you got to upgrade to a top feed, also just because I am to lazy to put all my parts in my signature dont mean I dont got them. I got everything you do but the header and up pipe. If something where to blow subi should build it stronger is my thinking, thats the reason why I didnt take any warranties other then the standard one. If it breaks, its weak and I can always buy a better one
    Socal
    3,790
    Yes the point of having a forum is to get answers and questions. But if your searching uncovered that WRXs use side feeds, that causes some concern.
    I don't care what parts you have...my point is again that if through your thorough searching, you came to the conclusion that you needed side feed injectors, you should do some better research before dropping in a bigger turbo. You may have more knowledge than your posts seem to exclaim, but it's never a bad idea on my part to stress extra caution for someone upgrading a turbo.
    Lastly, if it blows it's not Subaru's fault they didn't build it stronger. They build their stuff to handle 265hp. With anymore than that, the onus is on YOU.
    Jan 2011
    North Dakota
    290
    I've built little honda and some mitsushities from the bottom end up so I know the motor should be built and stuff can always go wrong. On other sites people ask the same question and they get responses that say only STI's have top feed and wrx only have side feed with an upgradable top feed option. Others say the opposite and no one has a for sure answer or no one wants to correct someone else.
    Socal
    3,790
    04-06 STI - Sidefeed
    02-Present WRX AND 07+ STI - Topfeed
    100bhp 3G Impreza ScoobyTune's Avatar
    Mar 2011
    Colorado
    134
    Quote Originally Posted by chongl View Post
    Just to re-enforce, checked my 08 WRX. Definitely top feed.
  1. FS: (DW) 650cc Top Feed Injectors **SOLD**
    By ntbass in forum Want to Sell
    Last Post: 04-27-2012, 11:53 AM
  2. Replies: 1
    Last Post: 02-25-2011, 05:31 PM
  3. Replies: 3
    Last Post: 02-25-2011, 01:37 PM
  4. Replies: 3
    Last Post: 10-27-2010, 05:57 PM
  5. Replies: 35
    Last Post: 11-19-2008, 10:01 AM
04 wrx top feed or side feed injectors
side feed vs top feed
side feed vs top feed injectors
subaru top feed vs side feed
top feed vs side feed injectors
top feed vs side feed sti
top vs side feed injectors
topfeed to sidefeed wrx
why are side feed injectors better then top feed
wrx top feed vs side feed
wrx top vs side feed injectors
