2010 wrx w/ Cobb stage 2 Overboost issue.
Results 1 to 10 of 12
    400bhp 3G STI robstunner's Avatar
    Oct 2009
    Chicagoland
    434
    Perrin Catted downpipe
    Perrin Cat back
    STOCK intake Filter
    Forge BPV running a yellow spring (15-23PSI)
    I did some datalog, and although they are not till redline, i still logged them and noticed that i am fairly above the boost target i should be. The man log i did i knocked out 18.7 PSI top, tapering down. but the mini log i did, where i just floored it WOT from a cruise, i hit 19.43 max.
    Can anyone else help me out and look at my maps? is there any other issues other than the overboost? i DO hear a light pitched howl at WOT and max boost so that's another oddity.
    Datalog 1 is the normal 3krpm and up
    Datalog 3 is the overboost i caught
    (I'm sorry but I'm posting this at work on my phone so I can't upload the maps onto here, so I'll have the link to the cobbforums thread till I gr home tomorrow night.)
    http://www.cobbforums.com/forums/sho...2-overboosting
    also, took the advise from Cobb and installed the LWG version of the stage 2 map. Here's what I've found:
    Well I installed the LWG map and all was good untill this morning. I hit 18.3 psi and if i recall correctly it should be at 16.8 with an acceptance of +/- 0.8. I did a datalog but it was on my way to work (where I am now) and I won't be able to upload it here until tomorrow. Temps were 44 degree outside. I asked Perrin if the downpipe might be restricing the wastegate at all and they said that should not be an issue. I do hear a wierd noise at times under full boost that sounds like a howl, might be normal for a downpipe tho I'm no sure.
    Any help or suggestions would be greatly appreciated.
    Thanks in advanced!
    Rob
    2500bhp Monster TougeMonster's Avatar
    3,474
    Re: 2010 wrx w/ Cobb stage 2 Overboost issue.
    What octane are you running 91?
    The 93 targets are right in-line with those targets. Also, if you are running the Perrin dp with the cat closer to the turbo than the COBB then your exhaust gases are flowing faster than the COBB unit so your boost will be higher.
    "It doesn't matter if your car is the fastest on the race-track. It's a different story on the streets, your car has to be fun, fast, and safe in any road condition." --- Keiichi Tsuchiya
    Oct 2009
    Chicagoland
    434
    Quote Originally Posted by TougeMonster View Post
    I'm running a 93 OCT map with 93 OCT gas. Am I safe then? Should I worry about the overboost?
  4. #4
    3,474
    Quote Originally Posted by robstunner View Post
    Target boost for stage 2 is 17.8 +-.8 so you are fine. Keep running the LWG map.
  5. #5
    Oct 2009
    Chicagoland
    434
    target boost for LWG map is 16.8 I hit 18.3
    target boost for non LWG is 17.8 I hit 20.3
  6. #6
    3,474
    The target boost for 93oct for either map is 17.8. The different boost targets are dictated by octane numbers and not by wastegate mapping. I think you may have read the documentation for 91oct by accident.
  7. #7
    3,474
    Here is the text:
    Stage2 91 MTv102 - Intended for an otherwise stock 2010 Subaru WRX MT vehicle running
    a turbo-back exhaust with a high-flow catalytic converter, and STOCK INTAKE SYSTEM
    WITH STOCK AIR FILTER ONLY. 91 or 92 octane fuels. Boost Targets: ~16.8psi tapering
    down to ~14psi by the 7000 RPM redline.
    Stage2 93 MTv102 - Intended for an otherwise stock 2010 Subaru WRX MT vehicle running
    WITH STOCK AIR FILTER ONLY. 93 or 94 octane fuels. Boost Targets: ~17.8psi tapering
    down to ~14.5psi by the 7000 RPM redline.
  8. #8
    Oct 2009
    Chicagoland
    434
    Here is the text:
    [b]Stage2 91 MTv102 - Intended for an otherwise stock 2010 Subaru WRX MT vehicle running
    WITH STOCK AIR FILTER ONLY. 91 or 92 octane fuels. Boost Targets: ~[b]16.8psi tapering
    [b]Stage2 93 MTv102 - Intended for an otherwise stock 2010 Subaru WRX MT vehicle running
    WITH STOCK AIR FILTER ONLY. 93 or 94 octane fuels. Boost Targets: ~[b]17.8psi tapering
    Right but the lwg is lower boost same octane
  9. #9
    3,474
    Here is the text:
    Open up the map. Target boost for both maps is the same. The WGD cycles are different.
  10. #10
    Oct 2009
    Chicagoland
    434
    Here is the text:
    you are right. Where did I read it was supposed to be 16.5 or 16.8?
  1. 2010 TP stage 1 with Cobb SF intake mild knock
    By Turbospeed in forum Tuning Fork
    Last Post: 02-08-2012, 02:27 AM
  2. 2009 wrx catless overboost issue
    By Foshoxtac in forum Subaru WRX General Aftermarket Talk
    Last Post: 07-21-2011, 08:14 PM
  3. Torqued Performance Stage 2 Map + overboost?
    By amill in forum Subaru WRX Performance Electronics and Gauges
    Last Post: 02-10-2011, 09:59 PM
  4. 2010 WRX Cobb Surgeline tuned stage 2
    By Transfer in forum Subaru WRX Dyno
    Last Post: 09-28-2010, 02:33 PM
  5. 2008 wrx stage 2 issue
    By Bobby2008WRX in forum Subaru WRX Newbie Support
    Last Post: 06-07-2009, 08:39 AM
06 sti stage 2 lwg hitting 20 psi?
09 wrx stage 2 overboosting
2010 wrx after stage 2?
2010 wrx stage 2 target boost
2011 wrx cobb stage 2 target boost
cobb stage 2 over boost
cobb stage 2 overboost
high wastegate map stage 2 wrx
overboost on cobb stage 2
torqued performance wrx hitting 20 psi boost
torqued performance wrx stage 2 overboost
wrx stage 2 overboost should i adjust wastegate arm
