Install RomRaider on Windows 7 64bit?
Results 1 to 10 of 17
    elwray's Avatar
    Central NJ
    2,552
    I can't seem to get it to install... the .exe installer just sort of "sits there" after hitting NEXT.
    I've tried the zip distribution and I put the new xml definitions in but it won't connect to the tactrix cable...
    I'm kind of lost here.... any ideas?
    And yes I am using Run as Admin....
    Central NJ
    2009 WRX Hatch DGM Premium - K&N Typhoon - Cobb TBE - Torqued Performance -Stage = 2*e( pi*i )
    2007 Honda VTX1300C
    150bhp 3G Impreza poohbear's Avatar
    Feb 2010
    186
    Re: Install RomRaider on Windows 7 64bit?
    Run in compatibility mode as windows XP service pack 2
    elwray's Avatar
    Central NJ
    2,552
    Well I got it to work... I should have tried WinXP SP2... I tried SP3 and no luck.
    Anyway I figured it probably had something to do with trying to install it on 64-bit Java when it's a 32-bit program. So I uninstalled my 64-bit Java as a test, and it installed just fine.
    Was able to connect to the ECU and read values in Logger. Didn't actually take any logs yet because I didn't remember off hand in the car what parameters to log.
    Central NJ
    2007 Honda VTX1300C
    Premium Sponsors
    eminehart's Avatar
    Dec 2008
    Portland, OR
    2,485
    I just moved up to windows 7 64 bit and had no issues.
    I did decide to take all my tuning files out of the program files folder. Now I don't need to worry about Run as admin to save my profiles or ecu or logger definitions. It is very nice. Although maybe not applicable to most I can now easily edit rom and logger definitions without having to save to a different location and move the file. It's very nice to have things figured out the next time around.
    Eric Minehart
    [URL=http://www.facebook.com/pages/Torqued-Performance/326469209950]
    100bhp 3G Impreza BRWRX's Avatar
    Apr 2009
    SP
    110
    Are you guys using the Java for 64 bit version or still this Java version http://www.java.com/en/download/inc/...pgrade_xpi.jsp (as recommended here http://www.romraider.com/Documentati...aiderFAQ#toc40
    Premium Sponsors
    eminehart's Avatar
    Dec 2008
    Portland, OR
    2,485
    It is the one in your link that I am running.
    Eric Minehart
    elwray's Avatar
    Central NJ
    2,552
    I'll check that out. I don't remember any more, but I have it running on my machine.
    Central NJ
    2007 Honda VTX1300C
    08subiewrx's Avatar
    Jun 2008
    Woodbury , New Jersey
    2,678
    8 times
    I have never been able to get RomRaider to run smooth on my laptop with Windows 7. Every time I get high into the RPM's when datalogging the program freezes... I eventually gave up and started borrowing my brothers older laptop. Definitely a very annoying problem for me..
    08 Wrb Wrx - Bone Stock! - Sold
    - Bought a house
    A Pillar pods for sale!!!!----->
    Miata Build --->
    Apr 2009
    SP
    110
    Well I am desperately trying to make my PLX SM-AFR work with RomRaider logger, but no luck, so I was doing it all again to make sure I have it all right. Hopefully I'll get it to work soon.
    50bhp 3G Impreza rollertoaster's Avatar
    Jul 2010
    67
    Quote Originally Posted by 08subiewrx View Post
    I had the same problem, if you put a micro sd card in the op2 and log to the card, it won't lock up. And you don't need a cable or laptop to get tangled up in.
  1. Romraider On Mac OS X
    By Martin265 in forum Tuning Fork
    Last Post: 06-01-2011, 07:21 AM
  2. RomRaider will connect, but won't log?
    By GravyRobber in forum Tuning Fork
    Last Post: 10-20-2010, 02:04 PM
  3. Tatrix & Romraider Question
    By mrswicknick in forum Subaru WRX Newbie Support
    Last Post: 07-18-2010, 12:25 PM
  4. RomRaider Logger - Which paramters to log?
    By elwray in forum Tuning Fork
    Last Post: 06-30-2010, 02:32 PM
  5. Romraider help!
    By 08subiewrx in forum Tuning Fork
    Last Post: 03-28-2010, 08:07 AM
how to install romraider
how to install romraider windows 7
how to windows 7 romraider
rom raider logger
romraider 64 bit
romraider 64bit
romraider for 64 bit
romraider logger win7
romraider logger won't connect, windows 7 x64
romraider windows 7
romraider windows 7 64 bit
romraider wont install
