Rear brembo's on 08 WRX
Page 1 of 25 1 2 3 11 ... LastLast
Results 1 to 10 of 243
    10bhp 3G Impreza ianparcher's Avatar
    New Jersey
    20
    Here is info on how to mount rear 08/09 STi Brembo's on 08/09 WRX.
    This is my own interpretation on how to do this. I will not be liable for any losses or damages: attempt at your own risk!.
    Parts used:
    2 rear 09 STi calipers w/ STI mounting bolts (Stock WRX caliper knuckle bolts are wrong thread and wont work)
    2 rear 04 STi power-slotted rotors were used. I got them cheep, thats why I used them. (regular STi Brembo rotors should work)
    When I mocked up the rear brakes I found 3 issues:
    First the rotors splash shield was hitting the back (inside surface) of the rotor. The fix I used was to cutting reliefs in the shield. This allowed me to bend it back.
    Second issue is a lip for the e-brake on the rotor. It protrudes past the inside surface of the rotor. It was contacting the backing plate on the knuckle. This was stopping the rotor from fully seating on the hub. The fix was to lathe off the metal lip about .150
    Third and final problem was the caliper was not centered over the rotor. It was about .165 outward. The fix was to fly cut the boss's on the caliper .165 to center the caliper body over the rotor. You could cut the bosses on the knuckles, but then you would have to use shims if you ever went back to stock. Now for the pic's, I did paint the calipers silver with black logos.
    1990 300zx TT-Sold
    2004 WRX-Sold
    2006 STI-Sold
    2007 Cooper S-Sold
    2004 GSX-R 600-Current
    2008 WRX Sedan-Current
    1300bhp 3G WRC 08lrWRX's Avatar
    1,301
    Re: Rear brembo's on 08 WRX
    Very nice work!
    Super Moderator MicMcKee's Avatar
    Jul 2008
    2,745
    Very nice,
    Haha now to find someone with the machines I need to get that done...
    Give it a look I've been busy...
    2500bhp Monster chongl's Avatar
    Socal
    3,790
    Nice! A pioneer that answers the questions a lot of people have. +1 for you.
    Do you know how much the brake bias is changed by?
    2009 WRX Sedan | Forman Custom Rotated GTX3076R Kit | Gruppe-S EL Header | TiAL 44mm EWG | Reversed STI Manifold | Invidia CBE | Perrin FMIC | Aquamist HFS-3 | Tarmac2 Coils | Stoptech 328x28mm BBK | Rota Grids 18x8.5 | 255/35/18 Star Specs | Whiteline 24/22 | Carputer | N-1 CS Lip |
    New Jersey
    20
    Bias should now be STi specs Front 77.6% Rear 22.4%
    Here are the front Brembos on the car
    1990 300zx TT-Sold
    2004 WRX-Sold
    2006 STI-Sold
    2007 Cooper S-Sold
    REX
    REX is offline
    2000bhp Monster REX's Avatar
    Mar 2008
    2,472
    nice work! did you have to modify the front caliper at all? what discs did you use up front? cheers!
    New Jersey
    20
    Quote Originally Posted by REX View Post
    Front installed with no issue's; used 04 STi rotor
    1990 300zx TT-Sold
    2004 WRX-Sold
    2006 STI-Sold
    2007 Cooper S-Sold
    2000bhp Monster June-Rex's Avatar
    Jun 2008
    Denver, Colorado
    2,252
    Man I want new brakes!! >
    08 OBP Hatch - <b>Torqued Performance</b> Stage ? on E85 355WHP/405WTQ
    BNR-68HTA, Invidia DP & CBE, Perrin FMIC, ELH & CAI, BC Coilovers 8K F/R, Rallitek Track Spec Sways and endlinks, and too much else to list!!
    950bhp 3G STI lurker's Avatar
    Dec 2007
    jersey
    954
    wow that looks good. think the wrx brembos would mount up the same way? i know the front is a direct fit but what about the rears?
    2008 OBS, WRX Cat Back, AVO Air Filter, Kartboy CP, BC Racing Coilovers, Whiteline: Steering Rack Bushing, F&R Swaybars, Rear Sway Bar Brace, Rear Subframe Bushings, ALK and Control Arm Bushings, Generic Front Strut Tower Brace, CF STI Spoiler/Front Lip & other little goodies
    New Jersey
    20
    Quote Originally Posted by lurker View Post
    I think the WRX never came with factory Brembo's. They did offer FHI (Subaru) 4 Pot 2 Pot calipers. I think there are write-ups on nasioc about 02-06 WRX fitment. I think you would run into issues with the rears. The parking brake diameter on the 08/09 is different then the 02/07 WRX. Maybe rotor off-set and boss mounting location. Also I think you would only gain pedal feel going with the FHI setup. I think they are smaller then the 08/09 brakes, again check over at nasioc.
    1990 300zx TT-Sold
    2004 WRX-Sold
    2006 STI-Sold
    2007 Cooper S-Sold
  1. WTS: 09 STI Brembo Front/Rear Calipers
    By reaper702 in forum Want to Sell
    Last Post: 07-22-2011, 12:15 PM
  2. New Brembo Rear Brake Kit
    By Ric WRX in forum Subaru WRX Brakes
    Last Post: 08-19-2010, 02:57 PM
  3. Help needed on Brembo GT rear
    By sookainian in forum Subaru WRX Brakes
    Last Post: 11-10-2009, 09:20 PM
  4. WTB rear brembo brake pads used
    By topScoop in forum Want to Buy
    Last Post: 09-27-2008, 01:55 AM
08 sti brembo rear calipers
08 wrx brembo
09 wrx rear rotor size
2012 wrx rear brembo adapter
brembo install 2011 wrx
cheapest 2011 wrx brembo adapter
rear bembo's 08wrx
sti front brake on wrx bias
use brembo brake rear gold wrx 08
what would i need to install 4 pot subaru brembo brakes on my 09 wrx
will sti rear brembos work on a 12 wrx
wrx brembo adapter
