Clutch squeak fix without taking the whole dash apart (nut/bolt style) - Page 2
Page 2 of 13 FirstFirst 1 2 3 4 12 ... LastLast
Results 11 to 20 of 124
Like Tree5Likes
Thread: Clutch squeak fix without taking the whole dash apart (nut/bolt style)
    2000bhp Monster Turbospeed's Avatar
    Sep 2010
    Edmonton, AB
    2,203
    Re: Clutch squeak fix without taking the whole dash apart (nut/bolt style)
    Quote Originally Posted by homer_atl View Post
    08lrWRX nice writeup. Can you describe your original problem?
    I have an issue on my 09 wrx, but havent gone to the dealership or really investigated it yet. I get a little squeaking noise during idle. It almost sounds like a
    belt squeak, but when i press the clutch pedal, it goes away. It can't be heard unless
    the radio is turned off. Is this the same issue you had? BTW, I had my motor
    replaced at 14k. I'm about 20k now. Not positive if i they replaced the belts, but it
    never squeaked before.
    I think your issue is your throw out bearing. Quite a few have had warranty on them. There are some threads around describing it in more detail
    TP stage1 - AEM CAI - Cobb CBE - Whiteline sways - Kartboy Endlinks - SS - GS MCB - GS HS - Whiteline Bushing Catalog - Group N Pitch Stop - Group N Trans mount - Rally Armour UR - Tint
    350bhp 3G WRX tb16ua's Avatar
    Feb 2010
    Syracuse
    389
    8
    Doing this tomorrow morning... I know you used 2 washers but have you had any issues with leaks? Ill probably paint over the exterior side to prevent some rust too. Im not sure how much water really makes its way down there but would rather do this once. Also how long of an extension did you use??? Thanks!
    NOW - 2011 STi sedan - TP Stage 2
    THEN - '10 EFI Logics Tuned WRX - Mustang Dyno 309 awhp / 348 tq @ 20psi
    100bhp 3G Impreza Dragonfueled's Avatar
    Jan 2010
    Union county NJ
    137
    So the welds break that hold the clutch pedal assembly not the firewall cracking around the clutch master cylinder? I wonder if the grimspeed master cylinder brace really would help then?
    09 WRX Stage 2 Protuned
    400bhp 3G STI Kurikaze's Avatar
    May 2008
    Texas
    402
    Damn.. I think this crap happened to me...my pedal creaks on slow depress ill post vid later
    Dealer denied me of warranty due to my replacement of my pressure plate earlier
    Sent from my MB860 using Tapatalk
    08 WRB WRX Hatch (5 Speed) - SOLD
    14' SWP BRZ (Manual)
    2500bhp Monster GravyRobber's Avatar
    Memphis, TN
    3,758
    15
    I hate Subaru. This is an OBVIOUS problem with our cars, yet they will deny warranty on it because they think it is something that us evil "street draggers" are doing to cause this problem. I was concerned that my firewall might be cracked, so I took it to the dealer. He said that they would be unable to warranty my car, even if it is a factory defect, because I have modified it. I know that is against the law, but it will probably cost more money/effort to fight them in court over it than it is to just fix it myself.
    While this is a great write-up, and I will probably be doing this myself this summer, I find it absolutely pathetic that it has to come to this. Why can't Subaru just acknowledge their fault, and fix our fucking cars?
    /Rant
    +1 for you, 08lrwrx for a great write up, and DIY solution to Subaru's problem.
    Feb 2010
    Syracuse
    389
    8
    Did it and it works.... So happy that the sound and shitty pedal feel is gone. I still have a little squeak when slipping the clutch in first but it's WAY better.
    The bolt that goes in at an angle is a real bitch. Make sure you have a socket joint to hold the bolt head while someone tightens the nut from the outside.
    I'm gonna rip everything apart again at some point and re-do that bolt because I forgot to put a washer on the interior side and want to add that and crank it down a bit more. Hope that will help will the remaining noise. Even if it doesn't go away 100% this was way worth it.
    EDIT********** Sound came back.
    Memphis, TN
    3,758
    15
    Hearing these positive reports makes me happy.
    May 2008
    Texas
    402
    ++ Thanks for this... I'll have to look into doing this soon. Flushed my slave cylinder for my clutch thinking that was it.
  10. #19
    Feb 2010
    Syracuse
    389
    8
    Quote Originally Posted by GravyRobber View Post
    Yea I'm glad it's working too... I'm sure when it gets warmer the small squeak that is left will go away. You in a cold climate?
  11. #20
    May 2008
    Texas
    402
  1. Clutch pedal squeak (Not clutch, TOB, or linkage)
    By 08subiewrx in forum 3G WRX Chat
    Last Post: 07-08-2015, 07:23 PM
  2. my clutch squeak/broken welds story
    By Peowraaku in forum Drivetrain, Transmission and Gear Box
    Last Post: 02-10-2013, 05:54 PM
  3. Squeaky squeak coming from clutch...
    By mike6789 in forum 3G WRX Chat
    Last Post: 01-26-2012, 07:41 PM
  4. Clicking noise from clutch (not squeak)
    By 09DGM in forum 3G WRX Chat
    Last Post: 03-06-2011, 11:20 AM
2002 wrx clutch loose feel and squeaking
2008 subaru wrx clutch pedal squeak
2009 subaru wrx clutch pedal squeaks
fixing screw hole in clutch without taking it apart
how to fix 2010 wrx squeaky clutch pedal
how to fix a squeaky clutch pedal on a wrx
squeaky clutch when engaging 2015 wrx
sti clutch squeak
subaru spot weld fixes
subaru wrx 13 squeaky clutch
wrx clutch squeak
wrx squeaky clutch fix
