Page 5 of 8 FirstFirst ... 3 4 5 6 7 ... LastLast
Results 41 to 50 of 71
Like Tree1Likes
Thread: Clutch squeak fix without taking the whole dash apart (nut/bolt style)
  1. #41
    1000bhp 3G WRC reaper702's Avatar
    Oct 2008
    Sin City
    1,011
    6
    Re: Clutch squeak fix without taking the whole dash apart (nut/bolt style)
    Quote Originally Posted by krntehk View Post
    anyone have a problem with the clicking noise when clutch is engaged and released on all 5 gears??
    This. Anyone? Is the squeak and clicking caused by the same issue?
  2. #42
    0bhp 3G Impreza mSelmon's Avatar
    Feb 2012
    4
    Here are some pictures of what you might expect to see after popping off your windshield wiper assembly
    and heres a close up
  3. #43
    10bhp 3G Impreza bicycle_wreck's Avatar
    Quote Originally Posted by mSelmon View Post
    That is gnarly. What year/mileage?
    2012 WRX
  4. #44
    Oct 2008
    Sin City
    1,011
    6
    Ok so I just got my WRX back from the dealership the second time. I took it last week and they told me the cause of the noise was that the spring and pedals need to be replaced. I didn't believe them and they insisted it would solve the noise. So they ordered the parts and they installed it today. Got the car back and of course it is making the SAME noise. So then the adviser tells me that they believe the noise is coming from the brake master cylinder and they ordered one to replace it.
    At this point I asked him if he even took a look at the welds on the bracket that seems to be a major issue on these cars. I even told him a local forum member had the same issue that they failed to fix and eventually led to the guy's entire pedal assembly coming off and the dealership then finally fixing it. He basically tells me he has to follow the procedure SOA sets for them and that he can't just order to take my dash apart to fix the welds just yet. He admitted that he doesn't believe the brake master cylinder will most likely fail to fix the issue at hand.
    If that is the case, he told me it took more than 2 months for them to fix the welds on the other local that had the pedal assembly fail. I can't believe it would take that long to fix the welds. I know it's a lot of work to take the dash apart and then put it back in, but more than 2 months??? WTF! Anyone who had their welds fixed by a dealership, how long was your car down?
  5. #45
    50bhp 3G Impreza mine1317's Avatar
    Mar 2012
    Silver Spring MD
    86
    might have to try this this coming long weekend. can't believe my 08sti with 38k miles has this problem already
  6. #46
    Oct 2008
    Sin City
    1,011
    6
    Well my dealership got the authorization from SOA to reweld the two POS welds on the firewall. Service adviser said more than likely it will take 2 months to fix. Looks like I'll be driving a base impreza for that time >
  7. #47
    0bhp 3G Impreza sconlan's Avatar
    Jun 2012
    I read a post recently where the dealership quoted 2+ months to do but wound up taking care of it in 8 days...gonna be taking mine into the dealer tomorrow with the same issues > hopefully all goes well and I can get SOA on my side! How did it wind up for you reaper?
  8. #48
    Oct 2008
    Sin City
    1,011
    6
    Quote Originally Posted by sconlan View Post
    Lol that was me. Yeah they got it done faster than they initially told me. All good so far. Zero noise or sounds when I press/depress the clutch. They should give you a loner that will bore you to death but it is a much needed fix both for safety reasons and to get rid of that annoying noise which just gets worse.
  9. #49
    300bhp 3G WRX Carter's Avatar
    Jan 2009
    Maine
    336
    slight squeak...2011 WRX 11,xxx miles...
    2011 Lightning Red WRX Limited | Perrin 3" Catted DP | Invidia Q300 Quad Tip Catback Exhaust | Perrin Stage 2 AP Tune
    Owner -
    Local Maine Subaru Community.
  10. #50
    10bhp 3G Impreza tcoffin014's Avatar
    Apr 2010
    Does this same issue cause the grindy clutch feel too? I kinda have the squeak sometimes, mostly when its wet and cold. But I usually have a grindy feel in my pedal. Almost like there's sand stuck in the pivot point or something. I've heard its a rusty throw out bearing, but they replaced that last time I was at the dealership. I'm gonna check my welds when I get off work and do this if that's what it is
Ads
  1. Clutch pedal squeak (Not clutch, TOB, or linkage)
    By 08subiewrx in forum 3G WRX Chat
    Last Post: 05-22-2013, 10:48 AM
  2. my clutch squeak/broken welds story
    By Peowraaku in forum Drivetrain, Transmission and Gear Box
    Last Post: 02-10-2013, 05:54 PM
  3. Squeaky squeak coming from clutch...
    By mike6789 in forum 3G WRX Chat
    Last Post: 01-26-2012, 07:41 PM
  4. Clicking noise from clutch (not squeak)
    By 09DGM in forum 3G WRX Chat
    Last Post: 03-06-2011, 11:20 AM
02 wrx clutch squeak in cold
2009 subaru wrx clutch pedal bracket
2009 subaru wrx firewall clutch spotweld repair
2012 wrx clutch pedal creak
2013 wrx clutch squeak
clutch squeak
fixing broken rivets with nut and bolt 2009 wrx
how to fix spot welds for clutch pedal for a 2009 subaru wrx dashboard
taking dash apart 2011 subaru wrx
wrx clutch squeak
wrx clutch squeak fix
wrx weld break fix
