cv boot destruction
Results 1 to 8 of 8
    500bhp 3G STI 08wrxsubie's Avatar
    Nov 2008
    louisiana
    517
    cv boot destruction
    seems while i was installing my springs i managed to pinch a tiny little hole in the front pasanger cv boot. grease went EVERYWHERE which is how i managed to find this. what do you think i should do? i need this fixed before sunday when i go back to school..... should i take it to subaru so they can blame it on me anyway or do you think they would fix it? could i just try to silicone the hole? how would i re-grease the inside(where all the grease leaked out of)?, should i buy a new one? any help would be appreciated..
    spark silver 08wrx sedan.
    320whp,322wtq
    build thread
    50bhp 3G Impreza soundserious's Avatar
    Apr 2008
    Toronto
    75
    Re: cv boot destruction
    You should be able to replace just the rubber boot, either DIY or pay Subaru, I doubt there gonna cover it under warranty (doesn't hurt to try though).
    If its only a tiny hole then don't worry about re-greasing, its when you tear that boot open and dirt and crap get in there is when you have problems.
    2008 OBP WRX Sedan
    2000bhp Monster June-Rex's Avatar
    Jun 2008
    Denver, Colorado
    2,252
    Well since I have had this happen to me already, I guess I can offer some help. So my boot got cut by my coilover install. We tried securing the boot with adhesive and that marginally worked. I talked to subaru, and they don't make boots for our model year car. You have to buy a whole new axle (according to them), since it's a non-serviceable boot. So you can ask for a Forester or outback boot (which is similar in size), plus the the collars, and take it to an axle repairman to get him to fix it. Or you can do like I did, and drive it until it dies and buy a brand new axle. I know thats the dumb way to do it, but the stealership wouldn't fix the boot since it was my fault.
    08 OBP Hatch - <b>Torqued Performance</b> Stage ? on E85 355WHP/405WTQ
    BNR-68HTA, Invidia DP & CBE, Perrin FMIC, ELH & CAI, BC Coilovers 8K F/R, Rallitek Track Spec Sways and endlinks, and too much else to list!!
    1500bhp 3G WRC TwentyDollarBil's Avatar
    1,861
    Quote Originally Posted by June-Rex View Post
    Major bummer
    Quote Originally Posted by 08wrxsubie View Post
    Wouldnt hurt to ask to see what local dealer(s) can do for you.
    You may also want to visit some repair shops, there may be a suitable replacement (non-subaru-oem). See what they can get for you and/or if they can repair it themselves (if you do not want to do it).
    Like June -
    Random thoughts/ideas of looking at potential different sealants, if you're willing to experiment.
    (adhesives (epoxy, crazy glue, etc), gels?, expanding foam (then shave it down after cured). Anything that might be used in the hobby or fix-it industry you might be able to use?). I don't know what might work and what wouldnt, test/read up first. Epoxy heats up and can melt certain materials.
    Or...Ride it out. It may still last for awhile. I road with a broken cv boot on my last car for quite a while (I didnt even know about it)
    When I went in for maintenance, my mechanic informed me that I had almost no grease left in it. So for me, it wasnt immediately noticeable. I guess it would depend on how fast you're losing the grease. My mechanic was able to obtain a non-oem suitable cv boot to replace the broken one.
    Good Luck!
    Parts, tuning, technical support, installations
    909-235-9526
    [url=
    Twenty's Journal -
    i JUST had this happen to me. i had my BCs installed and i guess in the process, the tiniest cut got made on my driver's side cv boot. i didn't notice til i went in for regular maintenance at the dealership. they told me that it happened most likely during the coil over install and that they would not cover it, of course. i went back to my installer, iag in md, and told them about it, and they spent about two hours trying to come up with a solution. as june said above, there is no part number for the cv boot on our cars. being a subie specialist, iag was able to pull a cv boot from a forester which fit perfect. stis and other wrx model years have a smaller diameter opening is what we discovered.
    thing is that you have a lot of centrifugal force and pressure in that boot, and even through my cut into my boot was negligble and inconspicuous, it had a good deal of grease splattered out already and it is not something you want to hold off on replacing, in my opinion. it is a very easy and more affordable repair now vs done the road. get it fixed with a forester boot as soon as you can.
    Nov 2008
    louisiana
    517
    yeah i figured it wouldnt be that much fun...
    320whp,322wtq
    build thread
    400bhp 3G STI 08vtwrx's Avatar
    Vermont
    406
    Exact same thing happened to me so I am running it dry too so dont feel stupid!!! If they want us to spend 400 bucks on a new axel im gonna get my use outta this one!!!
    Nov 2008
    louisiana
    517
    yeah they said they would warranty it but if they decide not to ill ghetto rig it somehow. im not spending 400$ on it. i made my own gasket out of some silicone for now... seems to be holding up
    320whp,322wtq
    build thread
  1. Replies: 11
    Last Post: 12-07-2012, 01:16 PM
  2. JPM Coachworks Shift Boot and eBrake Boot Install
    By FatMooze in forum Subaru WRX Do It Yourself Help
    Last Post: 07-18-2011, 12:01 PM
  3. getting a new shift boot/e-brake boot
    By Big Sky in forum 3G WRX Interior
    Last Post: 10-27-2009, 11:36 AM
bc coilover torn cv boot sti
bc coilovers cv boot sti
jpm coachworks super glue
subaru 2008 cvj boot grease everywhere help
