AIR PUMP DELETE / BARO Pressure Sensor
Results 1 to 10 of 12
    700bhp 3G STI johnt2k7's Avatar
    Nov 2008
    Eastern Shore MD
    727
    when removing the air pump it is necessary to retain the Barometric pressure sensor located on top of the passenger side air valve
    here are a few pic of the stock sensor how i cut it and what it should look like after
    Stock
    Cutting
    Finished sensor should look like
    i had access to a band saw which most will not but as seen on Nasioc it can be done with a SawSaw or hacksaw
    IMAGES
    https://imgur.com/a/A5BTyMY
    For anyone who may still need the pics, I was Pm'ed about them and figured id repost them here aswell.
    32
    Re: AIR PUMP DELETE / BARO Pressure Sensor
    so cleanly done. good job, sir. i need to get around to my delete. i have all the kstech plates, might as well.
    is that what you used?
    clamsjager's Avatar
    Feb 2008
    Waterford, Ct
    5,664
    19
    any tuning needed when doing this mod?
    2015 DGM WRX Limited..... cars not even here and the mod list is to long to list.
    Nov 2008
    Eastern Shore MD
    727
    Yea mine where KS as well
    You need to disable all the codes to take care of the CEL
    I also did fuel rails @ the same time. So I zeroed the per injector compensations and rescaled the MAF.
    Sent from Voodoo Galaxy S
    0bhp 3G Impreza chaddy74's Avatar
    Jun 2012
    Brisbane
    5
    i cant see the images >
    900bhp 3G STI ofspunk7's Avatar
    Sep 2009
    The Flat Four-est
    940
    The only thing I had to do with my was CEL removal. I am using my reader to clear them now, need to bug my tuner to clear them for good.
    09' WRX Base DMG ~ E85 NF Tune @ 23PSI 350WHP/360WTQ ~ Rota Grids 18x9.5 w/ Star Specs ~ Invidia Q300 Quad Tip ~ IPR TMIC ~ Forge BPV ~ GrimmSpeed Electronic Boost Controller ~ GrimmSpeed Master Cylinder Brace ~ GrimmSpeed Lightened Pulley ~ Walbro Fuel Pump ~ 930cc NF Modified Injectors ~ TurboXS Stealthback DownPipe ~ Mode Dual Adj SS ~ Whiteline Sways 24F/22R ~ RalliTek HD Endlinks ~ K&N Drop In Filter ~ DDM Lows & Fogs ~ Hellas ~ GrimmSpeed Tow Hook License Plate ~ Hawk HP+
    Jun 2012
    Brisbane
    5
    without the sensor attached I cant read boost pressures via the logger. I have done a complete removal of the entire air pump systems..... I have deleted the CEL in the ECU that was simple. I want accurate boost readings thats why i want the sensor in line.
    I have been trying to sort this for weeks !! Eric had the answer for me in one minute !! Da man
    32
    Quote Originally Posted by chaddy74 View Post
    there's a few other threads on here available through a search.
    one in particular with plenty of images: http://www.3gwrx.com/forum/index.php/topic,17542.0.html
    Jun 2012
    Brisbane
    5
    Thanks mate
    32
    Thanks mate
    you're welcome, sir.
  1. Need air pump delete info
    By boiboi9 in forum Inhalation and Exhalation
    Last Post: 01-09-2015, 08:04 AM
  2. Replies: 5
    Last Post: 09-11-2012, 05:13 AM
  3. Does a 20g REALLY need a air pump delete?
    By dwhite in forum Turbos and Nitrous
    Last Post: 12-30-2011, 04:23 PM
  4. Tire Pressure Sensor
    By OGB in forum Subaru WRX Technical Support
    Last Post: 02-13-2009, 10:35 AM
  5. Replies: 24
    Last Post: 03-02-2008, 06:04 PM
06 wrx baro pressure sensor
07 subaru impreza barometric pressure sensor
07 wrx baro sensor
14864aa020 06 wrx have a amaspher pressure sensor
how to delete secondary air pump on 08 subaru sti
how to remove the baro sensor on 07 wrx
remove bero sensor from sti
subaru barometric sensor
subaru sti baro sensor
wrx air pump delete videos
wrx air pump removal
wrx barometric pressure sensor
