1.5xtr turbo upgrade questions
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
    25bhp 3G Impreza kenny_'s Avatar
    Jan 2011
    39
    Hi guys,
    Thinking about about biting the bullet and getting one of these with the 10cm rear housing for my 09 wrx. I have a few questions and hoping someone can point me to the right direction.
    Firstly, I'll be using stock headers and uppipe. You guys think I can get peak tq on or before 4000rpm?
    I have a process west tmic and am I right by thinking I can get away with the hot side silicon hose to suit STI turbos?
    I'll be installing ID1000 injectors at the same time so intake manifold will most likely be coming off to make the install more pleasant which brings me to my next question, should I get the 3" inlet version of the 1.5xtr or stick with the 2.4" and reused the stock inlet hose. If 3", I noticed there's a few 3" inlet hoses around. Which one provides best fitment?
    Last question, is there anything else needed to complete the install? I want to make sure I have all parts ready so I can complete install over the weekend since I need the car for work.
    Any advice would be appreciated.
    Thanks
    Ken
    2500bhp Monster 06f250sd's Avatar
    Orange County, CA
    3,807
    42 times
    Re: 1.5xtr turbo upgrade questions
    I think you'll be able to hit your 4000 goal depending on your fuel....With e85 these 1.5xtr's spool roughly the same as the 20gxtr but make more torque.
    Yes, the process west sti hose will work with this turbo.
    I'd definitely get the 3" inlet, it will help out with spool. The best fitting 3" inlet right now is the AMR piece but you will need to delete your tgv's to make it work; KS Tech sells a nice kit if you don't have time to port/polish the insides.
    I'd add a 73mm ks tech intake, fuel pump and ebcs if you don't have it and make sure you have new gaskets for what you're pulling apart; other than that it should be a pretty basic swap.
    dur4ce's Avatar
    Jun 2009
    McLean, VA
    2,435
    12 times
    17
    I'm sure you've already thought about this in deciding to upgrade, but it wouldn't hurt to have $5k or so in the bank that you wouldn't mind parting with, in case your piston ring seals decide they've had enough.
    Aside from that, I second what Jason said.
    -Steve
    2009 WRB WRX hatch (+1 gear)
    300bhp 3G WRX nofr1ends's Avatar
    Jun 2011
    San Diego
    332
    What kind of horsepower do you think you are gonna see?
    2011 dgm wrx. invidia catless dp, spt exhaust, grimmspeed ebcs, fms fmic, one step colder plugs, dw 65c fuelpump, k&n typhoon intake. rce tarmac 2s coilover. gfb bov. whiteline rear toe arms. whiteline front roll center. whiteline rear adjustable control arms. im sure theres more..
    Jan 2011
    39
    I had a think about it. Im going to end up with the 2.4" inlet to save doing tgv del. I forgot all about fuel pump. Gotta add a walbro 255 to the list.
    I'll be definitely going into e85 since im changing injectors. I'm already running about 90% duty with the stock injectors and aquamist meth kit at 23-24psi.
    I already have grimspeed 3 port, k&n intank and txs down pipe
    To be honest I'm not sure how much power to expect but hopefully more than my vf52 without sacrificing too much of the fat power band it currently has. Seems like a few people getting really good results with STIs but I havent seen one on the wrx. Obviously my results won't be as good due to single avcs, stock header and stock cat back. But it would interesting to see how much power it makes pushing stock components.
    I dont expect the motor to go blow as I don't drive the car hard on a daily basis. But if it does then I guess I'll just have to get some forged pistons.
    450bhp 3G STI a fatal ode's Avatar
    Aug 2010
    Great Plains
    490
    subscrible dizzled
    2010 wrx GH
    Jun 2011
    San Diego
    332
    Quote Originally Posted by kenny_ View Post
    Nice well when you get it all figured out post a dyno! I'm curious
    Orange County, CA
    3,807
    42 times
    A few things, you don't need to pull the manifold to install injectors but if you are pulling the manifold, why not delete the tgvs and run a bigger inlet? Why would you want to keep the tgvs in place? With a 3" inlet, the turbo is going to spool quicker which is what you want. If you plan on running E85, your meth kit is pointless so I'd sell that and recoup some money. You might max the maf on the K&N intake with the new turbo so you might need to run a bigger intake like a 73mm from KS Tech.
    31
    Quote Originally Posted by 06f250sd View Post
    you're right - he likely will. man, now if there was only someone selling a used kstech megamaf intake at a great price.
    g'luck with the build, sir!
    Jan 2011
    39
    First off thanks for your advice.
    I was kinda questioning whether 3" was going to increase spool. But now thinking again I'll be kicking myself if it did so 3" inlet it is. Yea that was the plan to sell the meth kit to get money for injectors.
    Your right about maxing the intake as I'm already siting at 4.5v with my current setup.
    Monkiboy, you'll be receiving a pm shortly
  1. BNR Turbo's stock-fitment turbo upgrade for 08+ wrx
    By KurtP in forum Turbos and Nitrous
    Last Post: 10-03-2010, 02:50 AM
  2. turbo upgrade
    By sptwrx2008 in forum Turbos and Nitrous
    Last Post: 04-28-2010, 03:23 PM
  3. More 2.5i Spring/Shock upgrade questions....
    By NH8991 in forum Subaru WRX Suspension
    Last Post: 04-19-2009, 09:57 AM
  4. Questions be4 i upgrade to a bigger turbo
    By 2K8_WRX in forum 3G WRX Chat
    Last Post: 01-15-2009, 09:14 PM
  5. Turbo Upgrade
    By coopwrx in forum Turbos and Nitrous
    Last Post: 08-28-2008, 01:46 PM
1.5 xtr for 08 sti
1.5xtr
1.5xtr 10cm
1.5xtr vs 2.5xtr
1.5xtr vs vf52
20g xtr nasioc
blouch 1.5xtr 10cm wrx
blouch 1.5xtr 2.4 vs 3 inch
blouch 1.5xtr vs 20g
dom 1.5 10cm dyno
dom 1.5 xtr vs 20g
topspeed 1.5xtr
