passenger dashboard vent
Results 1 to 7 of 7
    0bhp 3G Impreza evergreenbar's Avatar
    May 2013
    3
    Vent has disconnected from housing. Is there a way to reconnect without taking apart the dashboard?
    Thanks in advance.
    700bhp 3G STI MercRising's Avatar
    Mar 2012
    Denverish...CO
    714
    21 times
    Can you not get at it by popping off your side plates to your dash and then popping loose the silver trim strip that goes across the dash horizontally? If you open your door and look on the side of the dash, unscrew and pop off the piece. Then you will have access to the screws that hold on the silver dash strip. The silver strip comes off pretty easy with a little gusto but sounds like you just need to undo the screws on the far side of the dash for the silver strip and get to the vent behind it. I've had mine off several times doing stereo work and such. It's not full access to the venting but, it does remove the air director and get you to the actual piping behind it, sort of
    Just a thought, hope you get it!
    My list:
    May 2013
    3
    Thanks for the suggestion, I'll give it a try
    32
    merc* has it exactly right. while really simple and less than five minutes to do, if you have any questions or need images, your FSM has the detailed directions and photos last time i scanned through quickly. use it, it's your friend!
    Mar 2012
    Denverish...CO
    714
    21 times
    You get'er?
    My list:
    May 2013
    3
    My son has car now so I'll have to wait to get it back to attempt. Thanks for the follow-up
    0bhp 3G Impreza chal.nikkal's Avatar
    Jan 2015
    Then you will have access to the screws that hold on the silver dash strip. The silver strip comes off pretty easy with a little gusto but sounds like you just need to undo the screws on the far side of the dash for the silver strip and get to the vent behind it. I've had mine off several times doing stereo work and such. It's not full access to the venting but, it does remove the air director and get you to the actual piping behind it, sort of.???
  1. Looking for bumper vent
    By Jack916 in forum 3G WRX Appearance
    Last Post: 08-30-2012, 03:58 PM
  2. full vent BOV / Cobb AP
    By kulle in forum Subaru WRX Performance Electronics and Gauges
    Last Post: 09-13-2011, 08:04 PM
  3. Small vent on dash - why?
    By Jonathan.Gardiner in forum 3G WRX Chat
    Last Post: 05-27-2011, 10:37 AM
  4. Spec C Roof Vent
    By 08vtwrx in forum 3G WRX Appearance
    Last Post: 02-06-2010, 10:20 PM
  5. Paint to match Dashboard
    By elwray in forum 3G WRX Interior
    Last Post: 01-08-2010, 11:09 AM
