Lights and Bulb Guide - Page 7
Page 7 of 7 FirstFirst ... 5 6 7
Results 61 to 70 of 70
Like Tree1Likes
Thread: Lights and Bulb Guide
  1. #61
    50bhp 3G Impreza cadfax's Avatar
    Aug 2011
    Boston, MA
    59
    Has anyone replaced their reverse lights with LEDs? If so did they use a load equalizer?
    '10 WRX OBP
  2. #62
    Re: Lights and Bulb Guide
    Quote Originally Posted by cadfax View Post
    Yes, and no.
  3. #63
    50bhp 3G Impreza Bullit62's Avatar
    Dec 2011
    Tehachapi, CA
    61
    Has anyone done the H11 to H9 mod and ended up with the low beams staying on when the highs are activated? My '09 now does this. I used the basic $15 Sylvania H9's from AutoZone, carefully trimmed the small plastic tab and filed
    enough of the large key to allow the bulbs to fully lock in the housing.
    Voila! Both sets of lights now stay on when I select the high beams. The highs go out when I click back to the lows.
    I'm not upset about the change, mostly curious as to why it's happening...
  5. #64
    25bhp 3G Impreza CRAZYHAWK's Avatar
    Jul 2010
    NORTHERN NJ
    26
    The lows are designed to stay on with the highs. You're good.
    Quote Originally Posted by Bullit62 View Post
    Has anyone done the H11 to H9 mod and ended up with the low beams staying on when the highs are activated? My '09 now does this. I used the basic Sylvania H9's from AutoZone, carefully trimmed the small plastic tab and filed
    2009 IMPREZA Sedan 2.5i /Auto Trans/ Premium /Satin White Pearl/ HID Kit/ HD Radio
  6. #65
    200bhp 3G WRX 2010 WRX Limited's Avatar
    Mar 2010
    Vancouver
    247
    Hey so what was your impressions of that mod? A lot brighter? I'm considering HID retrofit but maybe this would be enough impovement for now?
    AEM Meth Injection, Fast Motorsport FMIC, Grimmspeed EBCS, AEM Cold Air Intake, Invidia Catless Downpipe, Invidia Q300 exhaust, NGK 1 step colder Iridiums, DeatschWerks DW65c fuel pump, BC Racing BR Coilovers, Crawford Performance CF Wing, Gold Rota G-Force 18 x 8 1/2, AEM Gauges
  7. #66
    Dec 2011
    Tehachapi, CA
    61
    Quote Originally Posted by 2010 WRX Limited View Post
    I'm a happy camper! I live in a semi-rural mountainous area that has almost no public lighting and decent lighting is critical for me to keep the local fauna out of my grill/windshield/front seats. The OE headlights were better than my last car but the H9's are a huge improvement. The only change I'm going to make it to bend the "squirrel finder" tabs down as the seems to help the lights fill in the lower area a little better.
  8. #67
    0bhp 3G Impreza RushOne's Avatar
    Jun 2012
    Is it bad to put a 194 bulb in place of a 168? I put 194 LEDs in my license plate lights and they seem to work fine
  9. #68
    10bhp 3G Impreza Hargs STIR08's Avatar
    Aug 2012
    VIC, Australia
    17
    Awesome Sticky, thanks for this!
    Rota T2R 18x9.5 +38 :: King Springs Super Lows :: Road tune by ThrottleHappy
  10. #69
    150bhp 3G Impreza WRX09MD's Avatar
    Sep 2009
    MD
    197
    I know Im reviving it but its some useful info. 09 wrx
    Your low beams take a 1350-lumen H11 bulb. You can easily, safely, and effectively replace this with a 2100-lumen H9 bulb, which you ought to be able to find locally by seeking the high beam bulb for a 2008 Chevrolet Malibu. Use a good brand (GE, Philips, Osram-Sylvania) and stick to colorless clear bulbs, not any kind of "whiter light" bulb such as the Sylvania Silver Star scam. Can also get online, H9 bulb .You may need to shave a small ridge of plastic off the H9 bulb's connector so that the H11 socket will snap on. Other than that, it's a direct swap. The only disadvantage is shorter low beam bulb life — the H11 is optimised for very long life with relatively modest light output, while the H9 is optimised for very high output with relatively short life. Note that the H9 swap is not universal; it works well in projector-type low beams but is not safe in most reflector-type low beams or in fog lamps of any type.
    If you want to upgrade the high beams, go to your local Chevrolet dealer (or GM Parts Direct: Your direct source for Genuine GM Parts for a better price)and pick up two part number 15094219. Can also get them online, Philips HIR1 9011 Standard Headlight Bulb, Pack of 1 : Amazon.com : Automotive . That is a Philips 9011 bulb. They are not some tinted or overwattage version of 9005, but share the identical filament geometry and base architecture as well as the same power consumption.
    Here's the comparison:
    stock: 9005, 12.8V, 65W, 1700 lumens, 320 hours
    new: 9011, 12.8V, 65W, 2530 lumens, 320 hours
    The 9011 bulbs have a double-wide top ear on the plastic bulb base, this is
    to comply with the law requiring different bulbs to have different bases.
    The extra-wide plastic top ear is easily trimmed or filed to make the bulb
    fit your headlamp's bulb receptacle. Once that's done, they go directly
    into the headlamp, and the existing sockets snap on. Please see
    HIR bulb base modification for details.
    The best fog bulb is Philips 9006 X-treme Power Headlight Bulbs (Low-Beam), Pack of 2 : Amazon.com : Automotive but Even good fog lamps, which are relatively rare, are of very limited use to most drivers. Fog lamps should be turned OFF most of the time. They are meant to be used in foggy (or rainy/snowy) weather to help the driver see the edges of the road close to the car so s/he can safely make progress through foul weather at very low speeds. That is _all_ these lamps are designed, intended, and able to do -- and most of the ones available as factory or optional equipment or in the aftermarket aren't even capable of doing that. Leaving the fog lamps on at all times does not improve lighting safety performance, though many people do so in the mistaken belief that they can see better this way at normal road speeds in dry weather. See Daniel Stern Lighting Consultancy and Supply for more information, and while I tend to stay off the internet forums myself, there's a good thread (with a link to good, valid data in post #4) at How many of you actually NEED your fog lights? .
    kingsalami likes this.
  11. #70
    800bhp 3G STI kingsalami's Avatar
    OKC, OK
    802
    15 times
    Good stuff!
    Thanks for the info, WRX09MD!
    2009 WRX 5-door - Cobb catted DP/SPT CBE/Andy's OS tune/Process West TMIC/GT Spec EL header/Devil's Own DVC-30 Meth Injection/AEM CAI/STI Short Shifter/Group N tranny & motor mounts/2011 STI springs & Konis/22 & 22 sways/Rallitek end links/Whiteline chassis & suspension bushings
  1. anyone gotten a 3G wrx/sti to operate the fog lights independent of the lights?
    By Mattesonb in forum Subaru WRX Do It Yourself Help
    Last Post: 05-04-2012, 03:02 PM
  2. Want to do your own oil changes? (DIY guide with pix inside)
    By Super_HKS in forum Subaru WRX Do It Yourself Help
    Last Post: 05-26-2011, 10:35 AM
  3. Bling Lights Fog Lights Info?????
    By saintsfan1483 in forum 3G WRX Appearance
    Last Post: 05-10-2010, 07:10 PM
  4. THE guide
    By Fss_0f_Death in forum 3G WRX Chat
    Last Post: 02-23-2010, 01:16 PM
  5. HID 30k Bulb
    By SGD7774A in forum Want to Sell
    Last Post: 08-16-2009, 09:10 PM
02 wrx lights bulb numbers
06 wrx led headlight bulb replacement nasioc
07 wrx led headlight bulbs nasioc
2013 sti bulb list
2013 wrx light bulb list
2014 wrx bulb list
2015 subaru wrx bulb chart
2015 subaru wrx premium bulb list
2016 wrx bulb list
subaru light bulb guide
wrx 2014 replace bulbs nasioc
wrx bulb guide
