Boost Comparison (20psi vs. 24psi vs. 27psi) with Virtual Dyno and 50-100MPH Time
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By xluben
Thread: Boost Comparison (20psi vs. 24psi vs. 27psi) with Virtual Dyno and 50-100MPH Time
    900bhp 3G STI xluben's Avatar
    Oct 2010
    Minneapolis, MN
    941
    I decided to do some boost vs. power comparisons (just for fun). First I started with a few logs with the MBC backed out all the way. The car was hitting about 20psi and was basically flat to redline. Pulling them up in Virtual Dyno showed nice consistent results!
    Because that looked good, I decided to turn the MBC up halfway to where it normally is at. I did a couple logs and it peaked close to 24psi, with a little taper down to around 22psi. Then to finish it off I turned the MBC up to my normal spot and it was just barely touching 27psi and then tapering down close to 24-25psi.
    Looking at the boost and torque (for the 24psi and 27psi graphs especially) you can see that I probably did have a slight uphill for run 1 and slight downhill for run 2 of each set. This slightly affected spool and peak torque. But overall the results are very consistent.
    And here is the plot with just one run from each boost setting. Solid, incremental gains with each change in boost. This is a nice, easy way to see how increasing the boost can really bump up the power (assuming the turbo is still able to flow enough air).
    I took speedo videos for these runs and the 50-100mph times were as follows:
    20psi (400WHP Dynojet): 5.4 seconds
    24psi (440WHP Dynojet): 4.9 seconds
    27psi (480WHP Dynojet): 4.4 seconds
    I use the 50-100mph time as a benchmark for how quick my car is in the real world. Dyno plots only tell so much, actually seeing acceleration times helps to put it all in perspective. All of the runs were done twice (once in each direction) and the results were identical (peak numbers within 2WHP in Virtual Dyno and 50-100mph times within 0.05 seconds in the videos), so I think the results are pretty solid. There will be different results tuning, your car, your mods, and many other factors. So take it with a grain of salt, but I'm just glad to see the VD numbers do seem to go up inline with the 50-100mph times going down.
    Here's the speedo video if anyone is interested:
    Brian B likes this.
    | 2011 WRX | 5 Door | Black | Built Motor | Rotated PTE 6266 Turbo | STI 6 Speed |
    850bhp 3G STI dScooby's Avatar
    Mar 2011
    Houston, TX
    899
    12 times
    Wow beautiful..
    Give me a second...
    150bhp 3G Impreza Brian B's Avatar
    Aug 2012
    Gilbert AZ
    199
    9 times
    Thanks for posting!
    Hellastock STI Hatch
    SSM - Stage 2 - 275/310tq - Cobb Access Port - Invidia Catted DP - SPT CBE -
    - Pioneer/Fosgate/Audio Integrations System -
    150bhp 3G Impreza 08WRXRider's Avatar
    Aug 2012
    NorCal
    188
    Thanks for this set of tests. Very informative.
    Oct 2010
    Minneapolis, MN
    941
    Thanks everyone. Glad it's useful/interesting.
  1. Stock Baseline and TP stage 1 comparison Virtual Dyno
    By DtChDcTr in forum Subaru WRX Dyno
    Last Post: 06-27-2012, 03:57 PM
  2. Virtual Dyno
    By makikogi in forum Subaru WRX Dyno
    Last Post: 03-11-2012, 01:37 PM
  3. Virtual Dyno 2011 WRX
    By MuddyWRX in forum Tuning Fork
    Last Post: 04-03-2011, 12:14 AM
  4. Virtual Dyno
    By 09wrxrocket in forum Tuning Fork
    Last Post: 11-25-2010, 03:30 PM
  5. Virtual Dyno
    By powells85 in forum Tuning Fork
    Last Post: 09-16-2010, 11:01 PM
2006 sti 24psi boost
50-100mph times
virtual dyno consistency
wrx 20psi
wrx seeing 27psi boost
wrx virtual dyno
