loosing my mind trying to snake new speaker wire through the door
Results 1 to 5 of 5
    150bhp 3G Impreza josserman's Avatar
    Oct 2009
    175
    Title is pretty self explanatory....already tore both speaker wires that run through....can't get my snake all the way through. It's been 3 hrs so far. Got the other door done in 20mins this one is killing me. Any suggestions? My snake is getting blocked at the top or bottom grommet depending on which way I enter from the door or side panel.
    2010 WRX Premium - Cobb DP, EFI Logic Tune, 267hp 302tq @17.5psi, Whiteline rear swar, steering rack bushing, Eclipse AVN726E, Alpine PDX 4.100, JL 250/1, Hertz Components, JL w2 10", GPS, Sirus, backup cam, ipod, bluetooth
    2003 Honda s2000 Full-Race turbo kit GT30R 450 hp @17psi...and much much m
    750bhp 3G STI ecbmxer's Avatar
    Oct 2009
    Pittsburgh, PA
    777
    Re: loosing my mind trying to snake new speaker wire through the door
    I'm guessing you got this figured out already, but if not. Clothes hanger, bent out straight. Tape the end of your speaker wire to it real good and make sure any sharp ends are covered with electrical tape. Stick just a bit of WD40 or grease on it (not enough to make a mess) and it should slide right through that rubber tube. Prior to pushing it through, pull each end of the tube off the plastic holder thingy (technical term) on each end. Hope any of that makes sense, haha.
    2010 WRX SSM hatch; Invidia catless DP and Q300 catback; Torqued Performance Stage 2 OS; SPT Short Throw Shifter; Audio Stuff
    [url=
    src="http://i8.photobucket.com/albums/a48/eminehart/TorquedPerformanceTuned.gif" border="0" alt="" class="tcattdimgresizersigs" onload="NcodeImageResizer.createOnSigs(this);" />
    clamsjager's Avatar
    Feb 2008
    Waterford, Ct
    5,664
    20
    i just ripped the gromet out then put it back in after i got the wire through it.
    2015 DGM WRX Limited..... cars not even here and the mod list is to long to list.
    Oct 2009
    175
    yea I did get it through...took 3hr's and got cuts all over my hand....used a snake had my wife hold one of the grommets. For next time, I will know better to use some sort of lube.
    0bhp 3G Impreza subarnoob's Avatar
    Sep 2013
    2
    Name:  2012-08-08 11.58.52.jpg
    All you need right here.
  1. Front and Rear Door Speaker Mounting Depth question
    By mannly in forum 3G WRX Electronics
    Last Post: 11-15-2011, 02:13 AM
  2. 2011 Passenger door speaker rattle
    By Van-van in forum Subaru WRX Do It Yourself Help
    Last Post: 02-15-2011, 04:00 PM
  3. Passenger Door Panel Speaker Rattle!
    By FACTION95 in forum 3G WRX Chat
    Last Post: 05-26-2010, 02:26 PM
  4. Door Speaker Spacers
    By ICY WRX in forum 3G WRX Electronics
    Last Post: 05-12-2010, 10:12 PM
  5. wtf loosing 4th already?
    By yfzracr89 in forum 3G WRX Chat
    Last Post: 12-03-2009, 04:09 PM
how to run speaker wire s2000
s2000 door speaker wire
