JL Audio HD900/5 Mounted Under the Passenger Seat - Page 2
Results 11 to 18 of 18
Like Tree2Likes
Thread: JL Audio HD900/5 Mounted Under the Passenger Seat
    150bhp 3G Impreza Brian B's Avatar
    Aug 2012
    Gilbert AZ
    199
    9 times
    Quote Originally Posted by SUBLURU View Post
    This will be the first car I've ever tried to sound deaden, so I have been looking at lots of options. Basically when I get back, I'll be stripping the entire interior out of my car and placing CLD Tiles on the floor pans, wheel wells, firewall, inside the doors/liftgate, and most of the hatch area. Then I am I am going to lay 1/4" Close Cell Foam on the floor, hatch area, and inside the doors. Finally I'm covering it all with Mass Loaded Vinyl to give it a nice quiet interior. I got most of my ideas from www.sounddeadenershowdown.com. They have some good advice and sell everything you need. I plan on doing a write-up on the process once I get reunited with my car.
    Any progress? Here's where I'm at:
    https://www.wrxforums.com/forums/17-i...tml#post467304
    Hellastock STI Hatch
    SSM - Stage 2 - 275/310tq - Cobb Access Port - Invidia Catted DP - SPT CBE -
    - Pioneer/Fosgate/Audio Integrations System -
    100bhp 3G Impreza SUBLURU's Avatar
    Mar 2012
    Anchorage, Alaska
    137
    Quote Originally Posted by Brian B View Post
    None yet. I'm still deployed, but I have all the parts at home waiting for me to install. Luckily I get two weeks of rest and recovery to work on the audio system and performance upgrades when I get home. I'll have to check your car out when I get off tonight. They block pictures and videos here at work.
    1100bhp 3G WRC RedMed427's Avatar
    1,116
    Re: JL Audio HD900/5 Mounted Under the Passenger Seat
    If you haven't already chosen the front stage, I recommend the hybrid audio imagine set. Love mine even without an amp. You'll have to modify the sail pods a bit but its doable with patience and a dremel
    15
    ^^ I was just going to recommend the same. Imagine HAT 6.5'' coaxials. They're actually designed to have the tweeters remain a part of the 6.5'' and not be installed in the sail panel. I run them and the rear JL VRs with a 300/4v2, beautiful.
    Mar 2012
    Anchorage, Alaska
    137
    I ordered all of my audio equipment about a month ago, and it's still siting in a garage waiting for me to get home to set it all up. Here is the list...
    Head Unit: Pioneer AVIC x930bt (already installed)
    Amplifier: JL Audio HD 900/5
    Subwoofer: JL Audio 10W6v2
    Box: Audio Integrations Perfect Fit (Bought on the GB, thanks for setting that up Brian)
    Front Stage: JL Audio C5-650
    Rear Stage: JL Audio C5-650x
    Some 1/0 Gauge wire to complete the Big 3 and build a grounding kit
    New DC Power Engineering 180 Amp Alternator
    And some Dynamat to soak up some vibrations in the hatch area
    I was seriously considering the Hybrid audio setup, but when I chose the JL Amp, I couldn't find a hybrid component set that would handle the 100W RMS that the amp is sending to the speakers, so I got the JL C5s instead. The JL has a 3/4" tweeter that should fit in the sail without modifications, which is exactly what I am looking for up there.
    10bhp 3G Impreza kallis222's Avatar
    Aug 2013
    Dude i am totally against the amplifier under the seat because its very irritating for me specially i am also go through the same problem after that i adjust the amplifier in the back of the seat...
    15
    I agree, don't like underseat either. It's a mess down there, I can just imagine all the shit getting at my amp.
    0bhp 3G Impreza subarnoob's Avatar
    Sep 2013
    2
    I currently have a Pioneer GM-D8500M amp sitting underneath my drivers seat (I used the drivers side because in my GH, the sub box I built fits perfectly behind the left folding seat in the back, so I kept everything on the same side). The amp fits without any issue with the seat all the way lowered and the wires all run into the square factory carpet hole underneath the seat. I also have my vents underneath that seat taped up with that aluminum air duct tape so in the winter time I don't melt the internals. If you want a picture I can see about getting that.
  1. Roof mounted Monitor/dvd
    By Jack916 in forum 3G WRX Electronics
    Last Post: 03-27-2012, 03:11 PM
  2. Passenger seat height issue
    By DJK55 in forum Subaru WRX Do It Yourself Help
    Last Post: 02-23-2010, 12:41 AM
  3. snow tires mounted
    By kbreezy04 in forum Subaru WRX Newbie Support
    Last Post: 12-18-2009, 06:31 PM
  4. Passenger side seat height adjust
    By bschai in forum Subaru WRX Newbie Support
    Last Post: 12-09-2009, 11:27 AM
  5. Where have you mounted your Access Port?
    By Piker in forum Tuning Fork
    Last Post: 06-26-2009, 03:25 PM
how to install a jl audio hd900/5 amp
jl 900/5 under seat c6 corvette
jl audio hd900/5 sub power
wrx hd900/5
