Electrical Help Needed!!!
Results 1 to 4 of 4
    350bhp 3G WRX tb16ua's Avatar
    Feb 2010
    Syracuse
    389
    So I wired my boost and oil pressure gauges in my sti sedan the same exact way as my old wrx...
    Turned the key to accessory and they lit up and were working. I had the ground
    to a bolt behind the gauge hood, power to the 12v acc/switched, and illumination
    to the Illumination dimmer wire both to the radio harness wiring. Since i was
    testing this I made the mistake of just twisting the bare wires together (ILL
    Dim and 12v) and i accidently touched them together. Now they dont light up any
    more.... Checked the in cabin fuses and couldnt find any blown. Whatever ...I
    can still reach the mechanical boost gauge and I figured Id just mess with it
    later.
    Now part 2 and the real issue. Im trying to wire up a 6ch line out converter/line driver for my
    new audio setup. Its a cache coe6 and I have it tapped to the same 12v
    acc/switched for the remote in, and connected the other needed connections (12v
    constant, remote out and ground). As expected when I turn the car on the unit is
    not turning on. This leads me to believe the problem is with the 12v switched
    line. Is there anything other than the fuse I should check? When I temporarily
    plug the radio harness in the radio turns on when I turn the key to acc....
    Boggled.... any ideas?
    NOW - 2011 STi sedan - TP Stage 2
    THEN - '10 EFI Logics Tuned WRX - Mustang Dyno 309 awhp / 348 tq @ 20psi
    Feb 2010
    Syracuse
    389
    Anybody...?
    10bhp 3G Impreza subi08wrx's Avatar
    Mar 2013
    pa
    18
    what size fuze do you have for the taped connection it might be pulling to much for you.
    stage 2 torqued performance tune, h and r springs, tbe cat-less straight piped, short throw shifter, boost gauge and egt gauge, cold air intake, full ralitec front and rear sway bar kit.
    Mar 2013
    pa
    18
    also what fuse are you taped to for radio?
  1. Help with electrical issue
    By NoGraffix in forum Subaru WRX Performance Electronics and Gauges
    Last Post: 08-13-2011, 10:51 PM
  2. Question about relays for electrical gurus
    By Ogden in forum 3G WRX Appearance
    Last Post: 04-19-2011, 04:16 PM
  3. electrical issues?
    By coogs in forum Subaru WRX Newbie Support
    Last Post: 12-18-2010, 08:11 AM
  4. HELP: MECHANICAL VS. ELECTRICAL GAUGES
    By 3G SYNDICATE in forum Subaru WRX Performance Electronics and Gauges
    Last Post: 08-08-2010, 03:48 PM
  5. A little pet peeve or electrical gremlins...
    By Left Coast WRX in forum Subaru WRX Technical Support
    Last Post: 07-21-2008, 10:03 AM
blown duse
