amp and component questions
Results 1 to 7 of 7
    25bhp 3G Impreza blackened's Avatar
    Sep 2008
    Northern Virginia
    37
    Question amp and component questions
    I plan to amp the factory head unit on my 2013 premium without nav, and I would like to put component speakers in the front. As you can imagine, I want it to be louder and have better sound. I am not interested in a subwoofer. So two questions:
    (1) My front doors have stock tweeters in the corner by the mirror and A-pillar.. Would aftermarket component tweeters install seamlessly in this location? Recommendations?
    (2) If I go components in the front and coax in the rear, would a 4 channel amp be enough to run them all? or do I need 6 channels because the fronts would be component?
    Thanks for any advice.
    15
    Some aftermarket tweeters will fit. Some coaxials are designed to be entirely in the door slot, like Imagine HATs. Just depends. 4 channel.
    400bhp 3G STI doubleUareX2011's Avatar
    Chicago Suburbs, IL
    404
    10 times
    Alpine Type R for both sets, ran those in a previous vehicle and they were great. As well as not being overly expensive they can go absurdly loud before getting tinny or muddy depending on how you have them set up. Without a sub on an amplified system id probably have mine set up something like this:
    Treb +2
    Mid -5/6 (depending on preference)
    Bass -1/+0
    - Torque Solutions Short Throw- Holy Shift Kit- Group N Trans Mount- GT SPEC Strut Brace- AEM CAI- AVO Inlet- AVO TB Hose- Grimmspeed EBCS- Invidia Catless Downpipe- APM LS Catback- APM FMIC Kit- Forge BPV- DW65c Pump- ID 1000- GS EWG Up Pipe- Tial MVS- Kitsui 6k HID Kit- SMY Cluster- AEM AFR- AEM Boost- Rally Armor Flaps- GS Heatshield- PTP Lava Blanket- 04 STi BBS
    10bhp 3G Impreza 1oldman's Avatar
    Aug 2014
    Abilene, Tx
    23
    Any good 4 channel amp will do. 6.5" components with 3/4" tweeters will fill the OEM mountings. Rear door speakers are 6.5" shallow mounts. CDT makes some excellent reasonably priced components.
    2015 WRX Onyx Black Custom Bren tune, K&N intake.BBS RX 18" wheels
    Pioneer NEX4000, JL Audio C5 650, C5 650 Mid Woofers, JL Audio 10TW1-4, Alpine PDX V9, Axxess ASWC-1
    10bhp 3G Impreza chithead's Avatar
    Aug 2014
    Landis, NC
    Interesting suggestions here. Agreed, components will fit no problem, rear coax, and a single four channel amp. Easy as pie. Grab one of the harness adapters from AE64, add a line out converter from David Navone, and you are golden!!!
    10bhp 3G Impreza Jspec's Avatar
    Aug 2010
    OH
    22
    1. Most 6.5" components will fit up front. I had the Infinity Kappas and those fit but I had to trim off some plastics to get the tweeter to fit flushly.
    2. Depending on what amp and what speakers you are running, a 4 channel is perfect for what you are looking for.
    10 WRX Sedan - Lighting Red | Torqued Performance Stage 2 |TurboXS Catback Exhaust | CNT Catted Downpipe | K & N CAI | Kartboy SS, Bushings, Rear Diff Bushing | Grimmspeed Heat Shield | Tint | RA Mud Flap | Goodies from Kicker, Infinity, and Pioneer
    0bhp 3G Impreza Gsi30's Avatar
    Aug 2015
    2
    I have alpine r series in my truck they are really good speaker
  1. DIY Component speakers+tweeters for non premium sound system.
    By dwhite in forum Subaru WRX Do It Yourself Help
    Last Post: 11-11-2011, 02:11 PM
  2. Replies: 2
    Last Post: 12-30-2010, 02:19 AM
  3. New Car Questions
    By Call_er_Roxie in forum 3G WRX Chat
    Last Post: 10-31-2008, 05:28 AM
