AEM Boost Gauge Install, pressure sensor brass fitting and where to put it?
Results 1 to 6 of 6
    700bhp 3G STI MercRising's Avatar
    Mar 2012
    Denverish...CO
    714
    21 times
    No FINALLY getting around to installing the WBo2 and Boost gauges but, I have a small dilemma involving a couple of brass parts in the boost gauge box. It's the parts of the pressure sensor assembly . Where do I mount them? Am I supposed to drill a hole in the firewall and sandwich the firewall in between the male/female of this brass assembly, only leaving the part in the engine compartment for my vac hose to connect to and leaving the pressure sensor (orange female) end in the cabin?
    I just don't want this big ass thing floating around somewhere in the engine bay held by a zip tie.
    Cheers,
    John
    My list:
    Hoonigan808's Avatar
    Oct 2012
    Texas
    1,087
    50 times
    Glad Im not the only one asking that same question lol
    08WRX, TP Stage2, "Thou shalt not go stage 2 if thou hasn't installedeth a downpipe, unless thy wantest a checketh engine light. Lo, thou who installedeth a downpipe and has not tunedeth to stage 2 shall face thine engine's wrath, for thy dash shall become illuminated and proclaim "Hark, thou hast slain me", so sayeth the ECU."
    Mar 2012
    Denverish...CO
    714
    21 times
    I did end up just zip tying the sensor to another line and I guess that will have to work. I'll look for another spot when I have time.
    Also....the gauge is not picking up the signal from the sensor is the sensor failed the gas rag test. I have another sensor in route so I can determine of its the sensor or gauge. After speaking with AEM, I think the sensor was DOA:-(
    My list:
    Oct 2012
    Texas
    1,087
    50 times
    oh not good
    0bhp 3G Impreza kenpowrx's Avatar
    Dec 2013
    4
    I ran the vacuum hose into the car next to the fuse box. Then I attached the sensor to the hose and secured the sensor by the fuse box. Ran the wiring to the gauge from there. Everything worked great. You might try that. I called AEM and told them what I did and they said that was just fine.
    Mar 2012
    Denverish...CO
    714
    21 times
    Cool thanks, good idea. I'm all set on the boost gauge though.... This damn uego is really trying my patience now :-(
    My list:
  1. new spt boost gauge install
    By denato1 in forum 3G WRX Interior
    Last Post: 06-08-2014, 05:58 PM
  2. How To: Install a Boost gauge, 56K your screwed!
    By clamsjager in forum Subaru WRX Do It Yourself Help
    Last Post: 04-30-2014, 11:15 PM
  3. Boost and Oil Pressure Gauge Wiring and Install
    By 1st08wrx in forum Subaru WRX Performance Electronics and Gauges
    Last Post: 07-23-2012, 09:26 AM
  4. Boost gauge install
    By 08REX in forum Subaru WRX Do It Yourself Help
    Last Post: 05-17-2008, 03:30 PM
aem \boost gauge sensor location
aem boost gauge install wrx
aem boost gauge sensor
aem boost pressure sensor
aem boost vacuum sensor
can the aem boost sensor be calibrated
how to install aem boost gauge
how to install aem boost gauge on a 2012 jk 3.6
replacement boost sensor aem
where to place sensor wrx aem boost
wrx aem boost gauge install
wrx boost gauge install
