Just installed a new motor, did a check for everything and grounds and sensors all plugged in 100% but for some reason the temp needle pegs to hot right as you turn on the ignition! I have coolant in the car but even when cars cold a code reader saids the coolant is 248 degrees and that’s with it plugged in or not plugged in so it stays the same! Kinda lost please help!!!
