Brakes, wheels, brake fluid?! Ugh!
Results 1 to 10 of 10
    250bhp 3G WRX Hamstardj's Avatar
    May 2012
    Swfl
    258
    Ok so my wrx is quite shakey when I brake semi-hard to hard. Soo I'm thinking new rotors in front. Along with fluid, possible pads.but as I read on fluids... I came into a wall. Which fluid? I've read just get get cheap fluid. Because performance fluid needs more heat and attention. Can't lie, I'm trying to find a track I can race but it's slim pickings. Sooo mainly dd/street driving for me. What would anyone recommend for brake fluid?
    Also I've fallen in love with the bbs style 2009 STi wheels. Anyone know for sure they fit a 09 wrx hatch?
    2009 Subaru impreza wrx hatch.
    Cobb AP - Cobb STG 2
    Apexi turbo timer
    RCE regular guy (blacks)
    Grimmspeed up pipe (DEI heat wrapped and sprayed)
    CNT down pipe (DEI heat wrapped and sprayed)
    CNT quad tip exhaust (DEI heat wrapped and sprayed)
    PTP turbo blanket
    Rallyarmor UR
    TWM Phantom shift knob
    Cobb AP - TorquedPerformance stg 3
    Apexi turbo timer
    Kartboy f/r shifter bushings
    CNT down pipe
    PTP turbo blanket
    Grimmspeed Heatshield
    Grimmspeed EBCS
    ACT HD clutch
    ACT streetlite flywheel
    Group n Transmission mount
    NRG 4 point harness
    NRG harness bar
    Kartboy Short Shifter
    Whiteline postive shift kit
    Walbro 255lph
    2500bhp Monster 06f250sd's Avatar
    Orange County, CA
    3,807
    42 times
    Re: Brakes, wheels, brake fluid?! Ugh!
    ATE Super Blue or Motul RBF600. No the sti wheels wont bolt on, you'd need some adapters to run them.
    400bhp 3G STI CarlN's Avatar
    Apr 2009
    408
    i don't think that the super blue is technically street legal (not that you'd ever get a ticket for it i would hope!), but you could use ATE TYPE 200 which is supposedly exactly the same without the dye. a lot of guys over on the miata forum who track alternate blue and type 200 so they know when they've bled all the old fluid out.
    Tourqed Performance Tuned!. 08 3"catless tbe, kstech 73mm intake, aem meth kit. perrin elh, godspeed fmic, dw750s, walboro 255, grimmspeed ebcs, 08 sti springs/struts, megan front strut bar, eibach rear bar 22r, rallitek endlinks, perrin crank pulley
    May 2012
    Swfl
    258
    Quote Originally Posted by Simple Machines View Post
    Boo! Oh well on sti wheels. But are adapters pricey?
    Lol I live in Florida... Most non-street legal things are wayyyyy over looked! Lol yay!
    Hmm so between motul and super blue/ type 200. I feel like motul is the way to go mainly because of how often I read about people going with motul.
    Thx guys for input . Don't be afraid to school me in braking, I'm still trolling forums on it but personal experience is always what I look for in advice .
    Apexi turbo timer
    PTP turbo blanket
    Rallyarmor UR
    Apexi turbo timer
    CNT down pipe
    PTP turbo blanket
    Grimmspeed EBCS
    ACT HD clutch
    NRG 4 point harness
    NRG harness bar
    Walbro 255lph
    2500bhp Monster chongl's Avatar
    Socal
    3,790
    The 2 mentioned above are great...Motul also has a 660 and I am personally running Amsoil Series 600
    2009 WRX Sedan | Forman Custom Rotated GTX3076R Kit | Gruppe-S EL Header | TiAL 44mm EWG | Reversed STI Manifold | Invidia CBE | Perrin FMIC | Aquamist HFS-3 | Tarmac2 Coils | Stoptech 328x28mm BBK | Rota Grids 18x8.5 | 255/35/18 Star Specs | Whiteline 24/22 | Carputer | N-1 CS Lip |
    Orange County, CA
    3,807
    42 times
    Quote Originally Posted by CarlN View Post
    LOL neither are any of your mods in your sig...
    150bhp 3G Impreza apexone4697's Avatar
    Jan 2012
    oxnard, ca
    182
    i just installed carbotech bobcat pads up front, new stoptech ss lines, and motul rbf600 fluid. i used stoptech sp pads in rear. brakes feel very good. just make sure you bleed good. the motul fluid is pricey compared to ate.
    May 2012
    Swfl
    258
    The price is what does slow me on motuls. But if a the extra buck is worth while, then so be it. But if super blue is close then super blue here I come.
    Apexi turbo timer
    PTP turbo blanket
    Rallyarmor UR
    Apexi turbo timer
    CNT down pipe
    PTP turbo blanket
    Grimmspeed EBCS
    ACT HD clutch
    NRG 4 point harness
    NRG harness bar
    Walbro 255lph
    1000bhp 3G WRC reaper702's Avatar
    Oct 2008
    Sin City
    1,055
    7 times
    Quote Originally Posted by Hamstardj View Post
    Apexi turbo timer
    PTP turbo blanket
    Rallyarmor UR
    You know you have a double signature?
    May 2012
    Swfl
    258
    Lol just realized. Fixed it!
    Apexi turbo timer
    CNT down pipe
    PTP turbo blanket
    Grimmspeed EBCS
    ACT HD clutch
    NRG 4 point harness
    NRG harness bar
    Walbro 255lph
  1. Switch from stock to performance brake fluid
    By Skidder in forum Subaru WRX Brakes
    Last Post: 12-06-2011, 10:20 PM
  2. Quick question about brake fluid
    By SUPERSCOOBY11 in forum Anything Under the Sun!
    Last Post: 07-16-2011, 11:15 AM
  3. what brake fluid to you use?
    By jaa1197 in forum Subaru WRX Suspension
    Last Post: 08-28-2010, 01:13 PM
  4. How much brake fluid does this car require for a changeout?
    By DutchOven in forum Subaru WRX General Aftermarket Talk
    Last Post: 08-20-2010, 11:27 AM
  5. oem brakes - low pad, low fluid???
    By swong46 in forum Subaru WRX Brakes
    Last Post: 12-26-2009, 11:08 PM
