CHECK ENGINE, Traction Control, CRUISE warning lights all on
Results 1 to 10 of 16
    10bhp 3G Impreza snoxracer183's Avatar
    Apr 2009
    Thief River Falls, MN
    So I installed my stereo system in my car over the weekend and after two days I went out and started my car to go for a drive and all three of the lights stay on and the CRUISE light is flashing. Any ideas what this means?
    The only thing I had done to the car was disconnect the battery.
    2009 WRX Premium 5-door / Satin White Pearl / Pioneer AVIC-D3 w-10" Rockford HX2
    2500bhp Monster TougeMonster's Avatar
    3,474
    17
    Re: CHECK ENGINE, Traction Control, CRUISE warning lights all on
    You just went into limp mode. Do you have any diagnostic tools available to you?
    "It doesn't matter if your car is the fastest on the race-track. It's a different story on the streets, your car has to be fun, fast, and safe in any road condition." --- Keiichi Tsuchiya
    1500bhp 3G WRC Troa's Avatar
    Seattle, WA
    1,582
    you can disconnect the battery for 30 seconds or so and it'll reset your ecu. wont tell you what happened, and it may happen again, but if it will fix the lights and take your car back to the normal tune.
    The Blue Beast
    2008 WRB WRX Hatch - Fully Forged w/ Blouch Dom1.5XT-R - Parted out and sold....
    Build Journal -
    25bhp 3G Impreza bluedemon08's Avatar
    Oct 2008
    Carol Stream
    42
    check the Ig2 10A fuse under the dash I had same problem with tc/tpms lights on when I was trying to do navigation bypass.
    25bhp 3G Impreza alphadark's Avatar
    Jun 2009
    27
    Many local parts stores can check that code for free. It might not be related to your wiring.
    Apr 2009
    Well this is what my code reader gave me that I got today...
    Guess I'll be going to the dealer
    P2441 Secondary Air Injection System Switching Valve Stuck Closed Bank 1
    MIL ON
    MisFire Monitor Complete
    Fuel System Monitor Complete
    Comprehensive Component Monitor Complete
    Catalyst Monitor Complete
    Heated Catalyst Monitor Not Supported
    Evaporative System Monitor Complete
    Secondary Air System Monitor Complete
    A/C System Refrigerant Monitor Not Supported
    Oxygen Sensor Monitor Complete
    Oxygen Sensor Heater Monitor Complete
    EGR System Monitor Not Supported
    DTC for which Freeze Frame was Stored P2441
    Fuel System 1 Status Open Loop
    Fuel System 2 Status Not Supported
    Calculated LOAD Value 43.53 %
    Engine Coolant Temp 89.60 ¬?F
    Short Term Fuel Trim - Bank 1 0.00 %
    Long Term Fuel Trim - Bank 1 0.78 %
    Intake Manifold Absolute Pressure 14.77 inHg
    Engine RPM 1506 rpm
    Vehicle Speed Sensor 0.00 mph
    Ignition Timing Advance #1 Cylinder -64.00 ¬?
    Intake Air Temperature -40.00 ¬?F
    Air Flow Rate Mass Air Flow Sensor 0.00 lb/min
    Absolute Throttle Position 0.00 %
    Commanded Secondary Air Status Atmosphere / Off
    Location of Oxygen Sensor
    OBD Requirements Not Supported
    Time Since Engine Start 0 sec
    3,474
    17
    Bring it back to the dealer or remove the pumps.
    I say bring it to dealer.
    Super Moderator rallyshark's Avatar
    Dec 2007
    Myrtle Beach, SC
    1,397
    Quote Originally Posted by TougeMonster View Post
    Agreed with Touge, take it to the dealership. Should be covered under warranty with no problem.
    2008 DGM Impreza 5-Door Prem. 5MT
    950bhp 3G STI thegonz's Avatar
    Jul 2008
    phoenix new york !
    978
    i had that same problem once
    when i tried that grounding dealy on nasioc forum
    i guess one of the grounds kept looping and ended up causing all sorts of lights
    Apr 2009
    Just got the car back from the dealership. Just as expected the Secondary Air Injection Valve was malfunctioning and replaced in bank 1. Seems as if everything is back to normal.
    I am still debating claiming the lemon law on this car. Motor replaced at 1,100 miles. Paint on the fender peeling off and repainted. Turbo bracket came loose. And now this latest CE light. Car has been out of service for 26 days now and I purchased it March 24, 2009.
  1. ABS/CRUISE/CEL/TRACTION CONTROL LIGHT ON. CLUTCH RECENTLY DONE
    By xxxhpdrw in forum Subaru WRX Technical Support
    Last Post: 05-19-2011, 06:15 AM
  2. Check Engine + blinking cruise + traction control = limp mode : But
    By Zombie in forum Subaru WRX Newbie Support
    Last Post: 02-25-2011, 09:53 AM
  3. Replies: 8
    Last Post: 11-10-2008, 10:57 AM
  4. Check Engine, VDC, & Cruise control ALL Lit up?
    By TKBIGS in forum 3G WRX Chat
    Last Post: 06-09-2008, 05:52 PM
09 legacy check engine cruise and traction
2008 subaru impreza cruise light fuse location
2009 subaru impresza limp mode
2009 subaru impreza all lights flashing
2011 subaru impreza wrx abs flashes when starting
2012 subaru impreza traction control on cruse control flashing engine light on
2012 subaru impreza wrx all lights on dash
check engine, traction control off, cruise control, light on impreza fuse
multiple lights on dash 2008 subaru impreza
subaru impreza traction control light check engine and abs
subaru impreza traction control light on
subaru traction control light on
