Blackstone Labs used oil analysis (UOA) report share thread - Page 9
Page 9 of 9 FirstFirst ... 7 8 9
Results 81 to 90 of 90
  1. #81
    dur4ce's Avatar
    Jun 2009
    McLean, VA
    2,435
    12 times
    17
    Re: Blackstone Labs used oil analysis (UOA) report share thread
    ^^Nice to see a solid high mileage report. Thanks for sharing!
    -Steve
    2009 WRB WRX hatch (+1 gear)
  2. #82
    900bhp 3G STI Breezio's Avatar
    Jun 2010
    900
    So, it's not a wrx, but I thought perhaps some of you might find it interesting.
    This is my first analysis on my freight truck.
    181,000 miles and 12,000 on the oil.
    higher viscosity @12K miles then RotellaT6 @3K miles..??
    -- Jeremy
    09' WRX
    Sportwagen zum einbauen!
  3. #83
    700bhp 3G STI MercRising's Avatar
    Mar 2012
    Denverish...CO
    714
    21 times
    Over a year bump!
    Just got my diagnostic back from Blackstone. It's nice to know I can run the oil quite a bit longer and that overall my EJ25 is a happy lil guy overall on the TP2 tune. This was an oil change at 3900 miles and I use the Suby Dyno oil and OE filters.......It's hard to beat the $20 oil change my local dealership gives me, screw taking off the lower engine cover and recycling the oil on my own.
    Cheers, click to expand.
    Name:  Merc 4-27-13 Blackstone.png
    Just got another email after sending I some additional info about my WRX to Blackstone and asking about a few variances from norm on my report.
    Here's the response:
    "John: Thanks for the e-mail and extra info on your Subaru. It sounds like a fun ride and I don't blame you for wanting to hold on to it as long as you can. Boron, sodium, calcium, and magnesium are all additives in the oil itself. Their levels will change depending on the type of oil you use and high/low readings aren't usually anything to worry about. Sodium can also show anti-freeze, though I didn't call anti-freeze on this report because your wear looks so good and no significant potassium was found. Potassium is another marker for coolant.
    Let me know if you have any more questions.
    Sincerely,
    Ryan Stark
    Blackstone Labs"
    My list:
  5. #84
    Jun 2010
    900
    Popped back in here because I got another report done...
    54K miles and still running strong on original early 09' WRX motor with the bad silver bearing issue... :/
    -- Jeremy
    09' WRX
  6. #85
    dmk
    dmk is offline
    50bhp 3G Impreza dmk's Avatar
    May 2011
    Over the hills and far far away - in WNC
    51
    My first UOA. My third OC with Rotella T-6 and Purolator filters. I pushed my OCI to 6400mi this time.
    More Gs with Torqued Performance Stage 1 tune
  7. #86
    0bhp 3G Impreza ksgoh88's Avatar
    6
    First UOA. Mobile 1 5w-30 Full Syn. Stock blue oil filter. 4,071 mile OCI.
    Edit: Switched to Rotella T6 5w-40 still using Stock blue filter.
  8. #87
    100bhp 3G Impreza MarcRX's Avatar
    Apr 2013
    110
    Interesting to see the UOA reports from different year cars, oil brands and filters. But can any general rules besides changing oil often can be made? I know that many folks don't recommend Mobile 1 yet the UOA reports for those using it don't look that bad or different than other brands. Are there any difference if you use different filters? Many do use the stock blues.
    Quote Originally Posted by ksgoh88 View Post
  9. #88
    6
    I think honestly the only way to know is to get an oil test done, and let the test show you what you need to do. I've been running Mobile 1 from the beginning besides when I let the stealership do the first couple and judging from the oil reports, standard Mobile 1 5w-30 is just fine in my engine. I religiously change my oil and oil filters though, so it could just be down to thorough maintenance. Like most info on the internet, just take it with a grain of salt.
  10. #89
    Apr 2013
    110
    Think you're right that it's more a factor on how you treat your vehicle and that you often change the oil with recommended oil type and weight and proper oil filter.
  11. #90
    Jun 2010
    900
    Latest test, past warranty now and still running strong on original 'bad' silver bearings and Mobil1.
    I've come to the decision of preempting a spun bearing and am probably going to replace the shortblock before the silver runs out and bearings go...
    -- Jeremy
    09' WRX
  1. All Georgia subie owners report!
    By gman in forum Southeast WRX Owners
    Last Post: 06-05-2011, 11:19 AM
  2. 1st Blackstone labs report
    By miami-k9 in forum Engine Internals
    Last Post: 07-16-2010, 10:30 AM
  3. Official UOA (Used Oil Analysis) Thread
    By chongl in forum 3G WRX Chat
    Last Post: 08-19-2009, 01:35 AM
2013 wrx uoa
5w30 uoa
blackstone uoa
castrol gtx uoa
motul 5w30 x-clean uoa
motul x-clean uoa
pennzoil platinum oil analysis wrx
pennzoil platinum wrx
quaker state uoa
report used oil
where to get wrx oil analysed
wrx castol 5w 30 syntec
