Changing my timing belt... What else should I do - Page 2
Results 11 to 15 of 15
    400bhp 3G STI ikeryder13's Avatar
    Apr 2012
    Rialto
    422
    I Trust U Monki Lol
    Apr 2012
    Rialto
    422
    Is it necessary to change the oil pump o ring and the cam and crank seals? I can't find a how to on those either
    AC belt you can walk off and on, but it's miserable.
    800bhp 3G STI kingsalami's Avatar
    OKC, OK
    802
    15 times
    Quote Originally Posted by zulukingcrowned View Post
    I found a pretty easy method of working the AC belt off the pulley:
    Feed a piece of flexible tubing/hose in between the belt and the ribbed pulley as you rotate the crank clockwise. As the tubing is drawn into the pulley, it squishes & lifts the belt out of the grooves so you can push it off by hand or with a pry bar of some kind.
    2009 WRX 5-door - Cobb catted DP/SPT CBE/Andy's OS tune/Process West TMIC/GT Spec EL header/Devil's Own DVC-30 Meth Injection/AEM CAI/STI Short Shifter/Group N tranny & motor mounts/2011 STI springs & Konis/22 & 22 sways/Rallitek end links/Whiteline chassis & suspension bushings
    Apr 2012
    Rialto
    422
    I actually bought the stretch belt tool
  1. Missing 1 degree of timing
    By HiBoost in forum Tuning Fork
    Last Post: 08-23-2011, 10:44 PM
  2. 09 Stage 2 WRX - question on timing advance
    By BEETROOT in forum Tuning Fork
    Last Post: 02-28-2011, 07:34 PM
  3. timing
    By jsully72 in forum Engine Internals
    Last Post: 04-24-2009, 11:38 AM
2012 wrx changing timing belt
2012 wrx timing belt
2012 wrx timing train
do you change cam seals when doing wrx timing belt
gates tckwp328rbsf
subaru wrx 2013 timing belt change
subaru wrx sti changing timing belt
what other maintenance should i do when i change my timing belt
what should i change with timing belt wrx
when you do the timing belt what else shoudl you do
wrx timing belt change when
wrx timing belt replacement seals
