Transmission/ Differential fluid swap - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 25 of 25
  1. #21
    2500bhp Monster 424wrx's Avatar
    Jan 2008
    3,417
    17 times
    Quote Originally Posted by Jd617XXXXX View Post
    I used Honda oil filter for my 09 wrx . Fits like a glove.
    for what? this is about tranny diff oil swap. there is no manual tranny filter. as far as motor oil, ive never heard of a honda oil filter working on a subaru to date.
    vf-52 turbo, ptp turbo blanket, tp stage 3.52 tune, grimmspeed ebcs and aos, forge motorsports bpv, perrin catted downpipe, borla catback, tomei el headers and uppipe, perrin cai, perrin tmic, rallitek swaybars, avo endlinks, racecomp/bilstein cup kit with black springs, jna front lip, kartboy ss, 22b shift knob, rota tarmac3 wheels and re11 tires. best time, [email protected] 108, 1/4mile
    2014 legacy daily driver
  2. #22
    800bhp 3G STI kingsalami's Avatar
    OKC, OK
    802
    15 times
    Why risk smoking your engine over a $6 oil filter? And what does this have to do with a tranny/diff fluid change?
    What's the relief valve opening pressure on the Honda filter vs. the OEM one? If they're the same, you may be safe. If not, it's probably not a good idea to experiment with something so vital to the longevity of your engine.
    2009 WRX 5-door - Cobb catted DP/SPT CBE/Andy's OS tune/Process West TMIC/GT Spec EL header/Devil's Own DVC-30 Meth Injection/AEM CAI/STI Short Shifter/Group N tranny & motor mounts/2011 STI springs & Konis/22 & 22 sways/Rallitek end links/Whiteline chassis & suspension bushings
  3. #23
    25bhp 3G Impreza Jd617XXXXX's Avatar
    Jul 2010
    31
    The Honda oil filter fits 08-13 wrx/sti. I don't know about other subaru models. I been using honda oil filter since 09. The reason I used it because I work at Honda so it's free.
  5. #24
    2000bhp Monster Turbospeed's Avatar
    Sep 2010
    Edmonton, AB
    2,203
    Honestly that's even worse logic to use that oil filter, if your engine craters because of a free filter then your out of pocket at least 5k. Use at least oem subaru filters or subaru aftermarket ones...
    TP stage1 - AEM CAI - Cobb CBE - Whiteline sways - Kartboy Endlinks - SS - GS MCB - GS HS - Whiteline Bushing Catalog - Group N Pitch Stop - Group N Trans mount - Rally Armour UR - Tint
  6. #25
    100bhp 3G Impreza MarcRX's Avatar
    Apr 2013
    110
    Agree about not using something just because it's free. Also thanks for the info on accessing the front diff fluid and using the clear tube that will make things a little easier.
  1. Is transmission fluid salvagable?
    By imprezafreak3 in forum Anything Under the Sun!
    Last Post: 05-19-2012, 10:14 PM
  2. Transmission fluid change
    By Onsit in forum Subaru WRX Newbie Support
    Last Post: 10-27-2011, 09:08 AM
  3. Center differential fluid change?
    By elwray in forum Subaru WRX Newbie Support
    Last Post: 10-10-2011, 09:16 PM
  4. DIY Video on Rear Differential fluid change
    By Marukai in forum Subaru WRX Do It Yourself Help
    Last Post: 01-21-2010, 01:36 PM
  5. 5MT Transmission Fluid
    By 26525 in forum Drivetrain, Transmission and Gear Box
    Last Post: 08-22-2009, 05:05 PM
2013 sti transmission fluid change
2013 subaru impreza diff fill
2013 subaru sti transmission fluid change images
2013 wqrx differental fluids
2013 wrx differential fluid
2013 wrx sti transmission and diff oil change
2013 wrx transmission fluid
2013 wrx transmission fluid change
change 2013 sti transmission fluid
dif fluid for 09 wrx
transmission fluid cahnge 2013 sti
wrx diy rear differential and transmission 2012
