Urgent - dumb question about coolant - Page 2
Results 11 to 12 of 12
    500bhp 3G STI Onsit's Avatar
    N Bethesda, MD
    512
    16 times
    Quote Originally Posted by bmcsi View Post
    This is whats going on with me , running 23psi on e85 and I push coolant out like crazy. Normal driving with mild boost and I don't loose any.
    I did a few tests on my car with some cheap kits to test coolant for the presence of exhaust gases.
    Seems like my theory (engine is at 130k now), the heads will separate slightly under high boost in high gears, and force exhaust gases to pressurize the coolant system. As the systems are pressurized with exahust gas this displaces the system causing the radiator caps to open up and bleed off excess pressure (in this case coolant and exhaust gases) into the overflow container.
    After a "spirited" run you can see the coolant bubbling inside the overflow container. And my radiator hoses are hard as a rock after such a high boost run.
    None of this is present with normal day to day driving staying below 5psi max boost. I even went as far as to edit my tune map to Null out the wastegate duty cycle table to prevent my turbo from building more than 7psi.
    :: 08 OBP sedan | TP 3.52 | VF52 | TurboXS FMIC | EBCS | CNT Downpipe | Invidia Q300 | Walbro | KStech 73mm MAF | Group-N Mounts | Whiteline Bushings all around ::
    Couldn't tell you, clutch would slip if I tried to give it any juice. Not a bad theory, been awhile since I've seen a trail. Still, I'd be surprised if I could lift the heads.
    No cooling issues, no issues. Just a chore.
    Not headgasket.
  1. Dumb question about oil level.
    By amill in forum Subaru WRX Newbie Support
    Last Post: 09-17-2010, 02:22 AM
  2. im gonna go ahead and ask a dumb question
    By thegonz in forum Subaru WRX Suspension
    Last Post: 03-16-2010, 06:50 AM
  3. Kinda a dumb question...
    By 2009_WRX in forum Tuning Fork
    Last Post: 11-13-2009, 02:39 AM
  4. Dumb lug nut question
    By Viggen in forum Subaru WRX General Maintenance
    Last Post: 06-20-2009, 12:04 AM
  5. Dumb Oil Question
    By Left Coast WRX in forum Subaru WRX General Maintenance
    Last Post: 02-19-2008, 03:36 PM
wrx pushing coolant under boost
