Quick question about brake fluid
Results 1 to 6 of 6
    0bhp 3G Impreza SUPERSCOOBY11's Avatar
    Jul 2011
    4
    I was under the hood of my 2011 WRX just getting more acquainted with the platform when i noticed what looks like 2 brake fluid reservoirs is this right or am I confused. Also does the turbo have its own coolant reservoir?
    1300bhp 3G WRC therussiann's Avatar
    Jan 2008
    Lexington Park, MD
    1,333
    Re: Quick question about brake fluid
    the turbo has its owne resurvar that is taped into the main one so when you do a change you fill all 3 main turbo and overflow.. about the break fluid i think one is power stearing not shure i am kinda away from my car for the next 5 months so cant see..
    -MOD LIST-
    needs to be updated
    1100bhp 3G WRC CJ05's Avatar
    Jul 2008
    North Juarez Heights (aka El Paso)
    1,135
    Are you thinking about the brake fluid reservoir and the clutch fluid reservoir?
    2008 SWP WRX Torqued Performance Stage 3.52
    2500bhp Monster 06f250sd's Avatar
    Orange County, CA
    3,807
    42 times
    Quote Originally Posted by CJ05 View Post
    +1
    Jul 2011
    4
    Quote Originally Posted by 06f250sd View Post
    +1
    Yes I didn't even think of that I just saw that they both were DOT 3 and I didn't even think of the clutch thank you. Is fluid for the clutch the same as the brake fluid, and is there any negatives in stepping up the DOT recommendations.
    50bhp 3G Impreza surfriderspears's Avatar
    58
    One is brake, one is clutch. You cna use dot 4 as well. Just look at the bottle to make sure they are compatable.And yes they both use brake fluid.
  1. Brakes, wheels, brake fluid?! Ugh!
    By Hamstardj in forum Subaru WRX Newbie Support
    Last Post: 07-22-2012, 05:17 PM
  2. Switch from stock to performance brake fluid
    By Skidder in forum Subaru WRX Brakes
    Last Post: 12-06-2011, 10:20 PM
  3. what brake fluid to you use?
    By jaa1197 in forum Subaru WRX Suspension
    Last Post: 08-28-2010, 01:13 PM
  4. How much brake fluid does this car require for a changeout?
    By DutchOven in forum Subaru WRX General Aftermarket Talk
    Last Post: 08-20-2010, 11:27 AM
  5. Can brake fluid be changed with strut tower brace?
    By Nacron in forum Subaru WRX Suspension
    Last Post: 02-20-2010, 11:05 PM
dot 3 or dot 4 brake fluid on 3g 2008 impreza wrx
