Smoked the transmission in my 2010 wrx swapped it with the trans from a 05 legacy gt replaced the clutch as well : so the problem now is I press on the clutch and it won't disengage and allow me to shift into gear while the car is running however if I put it in gear and start the car it will move forward and back as long as I shut it off between shifting to reverse
Things I've tried
Bleed the clutch
Adjust the pedal throw
Installed new slave
Any insight would be appreciated
Video is the new slave freshly bleed and still feels like it wants to work
Does it look like it's pushing the fork enough ? 🤔 am I getting bleed by in the master cylinder
