So this is my build journal for my 2008 wrx sedan .
I bought this car in april 2008 in Grande Priaire, AB , CANADA.
This car was bought with the purpose in mind of a well rounded car for winter and summer and then it started, turbo addiction.
The car was never suposed to go this far but guess what i fell off the wagon and its a wolf in sheeps clothing .
For turbo setups i have had a vf52,hta68,gt3076 and gtx3576r ETS rotated kit i now have a PTE 6466 GEN 2 with a custom kit beign built in Russia as of 12, 2019.
For suspentions i have had megan coils,09 struts with eibach springs,bc coil overs, race comp tarmac 2 and now air lift performance with edo cvt setup.
I do my 90% of my own work minus the long block i had built by outfront motorsports and my paint spary work .I stripped the car and reinstalled all parts but the doors after paint and before hand.
been building the car since new and its been on and off the back burmer for 6 years.
Thanks to my family and eric my tuner at torqued performance both who had spent tons of time dealing with me being cheap lol and always giving me help .
Outfront V3 case
Cosworth CNC heads with 278/274 cams and complete cosworth valve train 10000rpm heads
Bore/Power Hone W/ Torque Plates
Outfront Motorsports 1/2" Head Stud Kit
Labor To Machine Block For 1/2" Head Studs
Manley 04+ Subaru WRX/STI EH257 100.0mm Bore +.50mm Size 9.8:1 Extreme Duty Piston Set
Manley Subaru EJ205/EJ257 5.216in L Turbo Tuff Pro Series I Beam Connecting Rod Set
Rotating Assembly Balancing 10000rpm
King Performance Rod Bearings 52mm STDX (Extra Clearance)
King Performance Main Bearings Thrust Position 5 STD
Killer B Motorsport Ultimate Oiling combo
Subaru New Cross Drilled EJ207 V9 Crankshaft
Fluidampr Subaru EJ Series Steel Internally Balanced Damper
Gates 04-08 Subaru 2.0L & 2.5L Racing Performance Timing Belt Component Kit (Belt Tensioner 4 Idlers)
Subaru JDM 12mm Oil Pump
Tomei Head Gasket 1mm Subaru 2.5L Turbo Models
OEM Gasket Set
1300 ID injectors
Radium Dual Hangar - in route
Dccd pro controller
Custom air to water CSF 1500HP Intercooler
IAG fuel rails
IAG dip stick
IAG oil pan
AMS intake manifold
Boomba throttle body
mishimoto 19 rom oil cooler
mishimoto thermostatic adaptor
Turbowerxs exa scavenger pump
custom low mount turbo kit
PTE 6466 gen2 6466 with ocd mod
I built fuel lines Feed 8an and Return 6an
Aeromotive regulator
ENDO CVT air tank
GS Master Cylinder Brace
ARK 2011 catback
Tial Qr bpv
Grimmspeed ebc
Mishimoto rad cap 19 psi
Custom Rad Shroud
Torque solutions pitch stop
Griffin triple pass 24”rad 20 an conversion
ZZP double pass air to water heat exchanger
ZZP single pass air to water exchanger
--------------------------------------------------------Suspension mods --------------------
GT spec adjustbale lcas
19x10 VIP modular 3pc rims
285/35/19 bfg comp 2
airlift performance air suspension
Megan strut bar
22mm front perrin ajustable sway
19mm rear perrin ajustable sway Energy bushings
Rallitek HD end links
Project mu b-force Brake pads
2010 sti brembo front calipers
2010 sti rear brembo calipers
2010 sti rear sub frame and axels and r180 and hubs
2010 sti front lca and hubs and axels
2010 sti 6 spd trans
----------------------------------------------------------Exterior mods ---------------
2011 wrx/sti full body swap minus roof skin and front doors
Varis rear spats
2010 black window trim
20% rear tint and front strip
HTauto grill
TWM shifter bushings
TWM shifter
Perrin shorty antenna
Carbon fiber mirror covers
Vleds color changing marker lights
Charge speed side skirts
2011 HTauto front lip
Treble racing rear window spoiler
Prova yellow mirrors and rear view mirror
2011 HTauto duffuser
JDM sti rear fog light set as brake light
------------------------------------------------------------Interior------------------------
Aem wide band
Drivers left Vent gauge pod
GT spec d shaped wheel blue stitching
Symcluster wrapped guage pod
Pioneer nav
Alpine mrx 110 x 3
Alpine type r 10" x 3
custom x3 10" sub box
Gaugetek vbg1 vent gauge
prosport evo oil gauge Black base coated all the silver trim
Seats all restitched in blue and wrx in the seat
2011 black a,b,c pillars,vent visors and map lights
Head liner wrapped in black swede
group n tranny mount
SS brake lines
kart boy rear shift bushing
SPT front lower chassis brace
treble racing roof over lay gloss black
Outfront V3 case
OEM Gasket Set
1300 ID injectors
Dccd pro controller
IAG fuel rails
IAG dip stick
IAG oil pan
AMS intake manifold
ENDO CVT air tank
ARK 2011 catback
Tial Qr bpv
Grimmspeed ebc
Custom Rad Shroud
Megan strut bar
Varis rear spats
HTauto grill
TWM shifter
Aem wide band
Pioneer nav
Alpine mrx 110 x 3
SS brake lines
