Love the look of the quad tips on the STI. Seeing as how the chassis of the car is similar, will aftermarket exhausts for the STI fit standard WRX wagons? I realize there is the need for a cut out on the driverside, but that is easily solved. Just curious if it will bolt up. Also, issues with down pipe and mid pipe fitment (STI TBE bolt up to the TD04?)
Found it
From user "Zoidmeister"
Dual exhaust is a custom 3" cat back using a late model Camero muffler made by Magnaflow. It has one 3" in and two out, on which I put two inexpensive Ractive chrome tips. I bought all the parts at Overseas Auto just of Main St in Vancouver. I removed one small resonator and I am very pleased with both the sound and the noticeable extra power. Down pipe, up-pipe and reflash at Rocket Rally next.
Nice retrofit. I believe the 350Z one can be used also.
Good Luck all of you
