it shouldn't rub, it's very close to stock
the STi has 18" x 8 wheels, I think, and it doesn't rub (but then again it has bigger fenders)
+35 should be fine...it will set pretty flush with the fenders...hopefully the fact that there 7.5 wont require any rolling or anything, stock height will be fine though
OGB had 17x7 +35 on his car for a bit. He said it didn't rub at stock height. 17x7.5 +35 I donno, haven't seen anybody do that yet but I think it would be damn close.
17x7.5 +50 is going to be fine.
if you want them to sit flush with the side of the car...about a 35 should be good ...50 will sit in alot ...you can probably pull of at least a 17x8.5 or 9 at a +35 with the right camber adjustments and you wouldnt need to roll the fenders
Im getting the cobb lowering springs so would 17x7.5 +43 work for me or would i have some trouble?
