1 - 5 of 5 Posts
Cutting it close with the rim size but with the tire size you are running should be ok. It shouldnt rub but even if it does, it will only be a little bit, can easily be rectified with a small camber correction.
I think you should be fine. That package is only 0.3" closer to the strut and 0.9" closer to the fender. Might need some camber correction and fender rolling, but I doubt you'd need spacers or anything else too drastic.
1 - 5 of 5 Posts
