1 - 20 of 30 Posts
Alright you guys asked for it,
Here's how it's got to go down, if you're going to post you need to post a time slip with it or I won't add it to the list...
Along with the time slip you need to post your major mods and year and Model,
I'm going to try and create some categories,
IE: Stock Turbo WRX/ STI, then figure out a way to run some modded categories,
Cheers,
~Mike
the car is a 2008 wrx premium 5 spd
stock turbo
spt cat back
perrin panel filter
twm ss
air box mod
3500 rpm dump
need to slip to get a real launch just never tried it
reation -.6401
60ft -2,2529
1/8 -9.4609
1/8 mph - 75.85
1/4 et -14.6279
1/4 mph-94.55
These rauns are with my 08 WRX sedan.
Mods are:
YimiSport tuning stage 2 tune
catless downpipe
At this moment I am still running the stock CBE and am not doing hard launches because I dont think the stock clutch is any good.
here is mine from opening day at oahe speedway in pierre south dakota.
as you can see from the 60ft i spun all of first gear.
im the car on the right btw
mods:
custom sri
custom tbe
custom fmic
walbro 255
tuned on e85
2009 WRX Dyno Tuned on 91 Oct CA pump Gas,
Perrin EL Header
Perrin Up
Cobb DP
Perrin CBE
AVO Fuel Pump
AVO Panel Filter
Accessport
"E85 tune + 1000cc Deatchwerks injectors soon to come!!!"
im on the Right
RT = .118
60' = 1.994
1/4 = 13.375 @ 107.121
Updated Time With E85 Tune!!
RT .142
60' 1.927
1/4 12.783 @ 112.783
rainy day with wet track!
Perrin EL Header
Perrin Up
Cobb DP
Perrin CBE
AVO Fuel Pump
AVO Panel Filter
Accessport
"E85 tune + 1000cc Deatchwerks injectors"
only 16PSI
Here is mine for my 09WRX.
Air-box hack
K&N panel filter
ERZ cat back
Torqued Performance stg 1 map
My "snow" tires
Car #697, [email protected]
Date: 4-24-2010
Place: Rockingham Dragway
Elevation: 350 Feet
Temp: 75-77 Degrees
Had 11-15 mph head wind (storm blowing in)
2010 WRX HB
Turbo XS Down pipe
Turbo XS Catted mid pipe
Turbo XS cat back
Cobb AP
Running Cobb Stage 2 93 Octane
BC Racing BR Coilovers
17x8 Enkei RPF1's in Gunmetal
The third run (12.969) was into a strong headwind. I think the car, as it sits, has 12.7s in it on a decent day.
Cleaned.
Let's keep this to time slips and times, make new threads for discussions.
got a time slip ? post it here and it will get onto the fastest 3g countdown
post your slip to get put onto the fastest 3g billboard count down
lets see what ya got so everyone can see where our 3gs are standing in the 1/4 mile world .
Thought I would post up mine. This was my second time at the track, still learning things.
09 WRX
Open Source Stage 1
Muffler Delete
Rear subframe lock down
Rear diff lockdown
Short Shifter with all bushings
First slip I'm only posting because I find the reaction time to be quite amazing, had a good 60' as well, but I was hot lapping at this point and clutch started slipping during this run.
Third slip was my first run, forgot I had traction control on so it start freaking out lol. This was also the point where I found out that I can run bellow 14 (first time fastest was a 14.1) and had to run and buy a helmet.
Fourth slip is the fastest.
R/T 0.151
60' 1.908
1/8 8.718 @ 81.25
1/4 13.578 @ 102.02
2010 wrx HB
aem cold air intake
import racing header and up pipe
perrin downpipe
clark turner e tune
all through stock catback
It was over 90 degrees out and extremely humid. car was heat soaking like a mofo. This was my second time at the track with this car. It was street night so no track prep. I think i have the launches down. On a good fall night with a prepped track there isnt a doubt in my mind ill hit 1.6 60 foots. I have a td06 20g, injectors, and fuel pump in my room right now, just waiting on a front mount so hopefully i can get all this on and hit 11's at the end of the season. I know for a fact if i went to a track with good DA and decent temps i could hit 12.4's easily, maybe even 12.3's. this stock intercooler is murdering me.
2010 wrx sedan
turbo xs catted tb
ap tp stage 2
typhoon
stock turbo
Ambient Temp: 58
Elevation: 1100
Weather: night time, cool, dry
Track and Conditions: concrete i think with tar over lay, flat track
Tires: stock dunlops
Car: 2009, wrx
Fuel: pump unleaded Sunoco 93 with 1/2 tank of gas
Engine/Power Modifications: Perrin light weight pulley, resonator in factory exhaust removed
Drive Train: Perrin SS
Suspension Modifications: Whiteline rear diff inserts, Perrin subframe lock down kit
1/4-13.38
MPH-100.65
60ft-1.87
2010 WRX Premium HB
Fuel: 93 Octane
Mods:
SPT catback
Perrin rear subframe bushings
Whiteline rear differential bushings
KB short shifter
These are my two best runs so far, should be able to shave another tenth or two off the overall 1/4 time if I can get my 60' into the 1.7s.
1 - 20 of 30 Posts
