1 - 2 of 2 Posts
Since you said Base model, I am assuming that you do not have the dual zone system. The fan is closer to the right... Is this also true when using heat (hotter on right?)? I don't see any indication of where you reside (Texas, Florida, etc.) so not sure if o/s temps play a role. Has it worked correctly in the past? So many questions, so little answers I know...
Close your center vents to see if it improves. If it does, you may have a leak in your vents. It is unlikely it is getting warm on the way to the left side...
1 - 2 of 2 Posts
