1 - 20 of 27 Posts
perrin 3inch sedan catback and stock parts
I have a bunch of parts to sell. Price includes
shipping unless otherwise noted. I only accept paypal.. I will entertain offers.
Some Items I would prefer pickup due to weight. I am located south of Chicago.
Perrin 3” catted downpipe – Wrapped SOLD
Agency Power Upippe-wrapped SOLD
fastmotorsports top mount SOLD
Tdo6 20g SOLD
Stock rear rotors from 2011 STI. Very low miles.
2011 Stock brake pads. SOLD
Stock timing belt off 2011 sti 24k miles
2011 sti stock drivers side A pillar
window rain guards.
2011 STI Stock HID bulbs. SOLD
Perrin Postivie Steering response Kit, Adds 0.6 degrees of caster. These will only fit 2011+ STI $150
http://www.perrinperformance.com/sub...esponse-system
2011 STI air pump part
2011 STI stock fuel pressure regulator part
Stock TGV motors
Stock turn signal relay and bulbs
2011 STI Stock carpet mats SOLD
2007 STI Fuel damper SOLD
2011 STI stock BPV, no hose SOLD
Serial to usb cable for wideband
08+ Whiteline front camber bolts SOLD
2011 STI stock fuel pump
Group A lightweight power steering pulley. This is a fine spline pulley, you will need to check what you have (fine or course)
Walboro 255 fuel pump SOLD
2011 Stock rear control arms, trailing arms and toe arms
3" stainless steel weld on resonator, 18" in length SOLD
3" weld on resonator, 12" in length stainless steel SOLD
08+ 3" perrin dual tip catback exhaust.
You will need new gaskets and a new 3" V band
GrillCraft Front Lower Grill SOLD
GrillCraft Front Upper Grill SOLD
Stock rotors Front(SOLD) rear from 2011 STI. Very low miles. The first thing I
changed when I bought the car new. They have been sitting since then.
I prefer pickup due to weight.
[/URL]
Stock timing belt off 2011 sti 24k miles $20
2011 sti stock drivers side A pillar $20
rain guards. SOLD
STI
$150
PERRIN Performance — — Positive Steering Response System
2011 STI stick High beams. These worked when they were taken out but have
been sitting. The yellow crap inside is from when they are on as a daytime
running light. There is a mod to disable this, I did it to my new blue ones.
These will be sold as is, I will not take these
back
$20
2011 STI air pump part $25
2011 STI stock fuel pressure regulator part $25
Stock TGV motors $ 35
Discussion Starter #2 (Edited)
Stock turn signal relay and bulbs $20
Serial to usb cable for wideband $ 20
2011 STI stock thermostat $ 10
2011 STI stock fuel pump $20
Alternator pulley $10
will need to check what you have (fine or course) $60
2011 STI stock ebcs $15
2011 Stock restrictor pill $ 10
2011 Stock rear control arms, trailing arms and roe arms $ 100
Discussion Starter #3 (Edited)
front grill ONLY fits 08-10 SOLD
08+ 3" perrin dual tip catback exhaust. I will sell
the mid epipe and Y pipe separate from the ael back.
The Y pipe narrows down to stock size. The axel back is also the stock size.
You will need new gaskets and a new 3" V band $650
Discussion Starter #8 (Edited)
Flexfuel emblem $6
License plate relocation kit. This allows you to not drill into your bumper
to mount a front license plate. You put the black rubber part into the JDM
square holes, and then tighten the bolt. You will need to put new 3M tape on it.
$30
Discussion Starter #16 (Edited)
Parts for sale within the
next week:
Perrin Catted Downpipe SOLD
(wrapped )
Agency power uppipe. SOLD
Fastmotorsports Top
mount - DEI reflect-a-gold wrapped + zerosports splitter (cut to fit the huge
top mount) SOLD
Bump. My Synergy tdo6 20g is for sale. I bought it new from forman performance. 10k miles no shaft play. Looking for 650ish shipped.
get the topmount too while you are at it. Looking for 550ish shipped.
1 - 20 of 27 Posts
