Very trueSo i dont think a good fit sway bar should break the oem front endlink, its the bars that are a bit too short that can break it.
This would also be how to get the most out of the sway bar upgrades, breakage-wise though, the OEM units can usually handle the upgraded sways under normal driving conditions.OEM sockets are made of plastic and just not as strong. Sooner or later you will get more play out of the endlinks.
Depends what you are doing while it broke and how hard you were cornering. But potenitally, yes, it might.If the front endlink does break during a turn/cornering, will my car loose control?
Me too. Sean at RalliTEK assured me it was not going to be a problem. We shall see.I have the Rallitek rears and they are good.
I had Whiteline in the front but took them out b/c of clunking sound. I have Rallitek in the rear with no sound what so ever. I went back to stock in the front.Well my endlinks are noisy. I have the whileline endlinks upfront and rallitek in the rear. I am using the cobb front and rear sways with Megan Coilovers. Anyone with similar setup have the same noise? If not what what endlinks are you using?
