1 - 6 of 6 Posts
perrin has had a number of sway bar fitment issues in the past. I wouldn't be entirely surprised if the endlinks didn't fit right. though, don't the perrin endlinks use spherical bearings? i don't understand how the sway bar would bend the endlink. What setting were you installing the sway bars on?
Hey noticed your post. I have the same setup now but 25mm. You will need the endlinks as the unit is not the correct one for the STi. You will need to put about 2 inches worth of spacers on each side to make it fit and make the links perpendicular to the ground or else they will break. Hope I got to you in time.
I returned the perrin endlinks and just using the stock endlinks with my 25mm front bar.
Cool, I was just worried about the guy with the STi. He will have the same problems as I did if he bought the unit assuming fitment for the STi. WRXs and Legacys will fit perfectly.
1 - 6 of 6 Posts
