1 - 10 of 10 Posts
call me crazy i have been searching to see in the search and looking havent seen any post has anyone dynoed with a cai and cat back .just wondering if there is actually any way to beleve the sport compact car article hp figure.
intake exhaust and a fmic dynoed at 196hp and 235tq on my car..stock downpipe..stock tune
what dyno was that?
someone here with an 08 hatch got around 250 (crank) with custom turboback exhaust and AVO intake
it was on whatever dyno hot import nights uses on there mobile dyno
i have cobb 3''downpipe and crawford performance 3'' exhaust on my sedan with PDX stage 2 and im putting down 220whp and 290wtq. soon im going to do the cold air from perrin and protune it, and it will be up at 250whp and 300wtq
that is what i would like to have you think if i keep my front down pipe section and just replace the rear section with perrin high flow i will get a cel with my spt cat back ?
and your running an fmic with the stock turbo?? hows the lag?
it was a dynojet and at the time it was in nc..so close to sea level...and there was a little bit of lag with the fmic...i have since went to a big tmic but the fmic made up in top end what it lacked in low end...also someone mentioned running rich with the setup...when i was dynoing they had an wideband in my exhaust and they said i was running below 10s under full boost...also it was 97 degrees when i dynoed and they had one tiny fan so that may hinder the numbers a little bit...also my friend w/ an evo 9 dynoed 30 less then when he was tuned and an is350 on spray did 30 less then before so i see a trend
1 - 10 of 10 Posts
