Just wanted to know if anyone had any insight to the AVO intake. Should I expect alot from it or not and should i be looking for any problems it might cause. Thanks
you're going to need some kind of engine management
Discussion Starter · #3 ·
Thanks, i will have to look into it
I dont know if its an option for you right now but if you buy an AP from Rallitek they can provide you wit a protune including the intake
I bought my DP, intake and AP from Rallitek and they sent me a custom protune for my goodies!
Were there any other components needed for your pro tune?
So in order to install an intake you need an access port and a new ecu map??
You could just take it somewhere to get tuned. I think the AP option is better though because it allows you to return your car to a stock map and most of the vendors out there will provide you updates down the road.
There's a few threads here about the AVO intakes. According to Sean at Rallitek, the thing is pretty much useless until you start really building your motor. You're better off putting that money towards a TBE and an AP at this point.
