Here's the specification information, thought people may like this in a handy location for reference:
BODY STYLES
4-door, 5-passenger
5-door, 5-passenger
ENGINE
4-cylinder horizontally opposed (Boxer), double overhead-cam (DOHC), turbocharged/intercooled
Displacement 2.5-liter
Horsepower 224 @ 5,200 rpm
Torque (lb-ft) 226 @ 2,800 rpm
DRIVETRAIN
Symmetrical All-Wheel Drive standard
Transmission types
Standard: 5-speed manual transmission
Optional: 4-speed electronic automatic with SPORTSHIFT manual control
Gear ratios, manual: 1st gear: 3.166
2nd gear: 1.882
3rd gear: 1.296
4th gear: 0.972
5th gear: 0.738
Reverse: 3.333
Gear ratios, automatic: 1st gear: 2.785
2nd gear: 1.545
3rd gear: 1.000
4th gear: 0.694
Reverse: 2.727
Final drive ratio
Manual: 3.900
Automatic: 3.900
CHASSIS
Unitized body construction with Ring-Shaped Reinforcement Frame structure
Suspension 4-wheel independent
Front Strut-type with lower L-arm
Rear Double wishbone with upper A-arm
Brakes Power assisted 4-wheel disc with 4-channel, 4-sensor anti-lock brake system (ABS) and Electronic Brake-force Distribution (EBD)
Steering Rack-and-pinion with power assist
Wheels 17 x 7.0JJ aluminum alloy
Tires 205/50 R17 all-season
EXTERIOR DIMENSIONS
Wheelbase 103.1 in. (2,620 mm)
Length
4-door: 180.3 in (4,580 mm)
5-door: 173.8 in (4,415 mm)
Height 58.1 in (1,475 mm)
Width 68.5 in (1,740 mm)
Fuel capacity 16.9 gal
Curb weight
5-speed manual 3,142 lb (1,425 kg)
4-speed automatic 3,208 lb (1,455 kg)
INTERIOR DIMENSIONS
Headroom front/rear 40.3/37.6 in
Legroom front/rear 43.5/33.5 in
Shoulder room front/rear 52.8/53.2 in
Hip room front/rear 53.4/53.3 in
BODY STYLES
4-door, 5-passenger
5-door, 5-passenger
ENGINE
DRIVETRAIN
Transmission types
2nd gear: 1.882
3rd gear: 1.296
4th gear: 0.972
5th gear: 0.738
Reverse: 3.333
2nd gear: 1.545
3rd gear: 1.000
4th gear: 0.694
Reverse: 2.727
Final drive ratio
Manual: 3.900
Automatic: 3.900
CHASSIS
EXTERIOR DIMENSIONS
Length
Curb weight
INTERIOR DIMENSIONS
