1 - 10 of 10 Posts
So atleast once a day i would get white/blue smoke out of the exhaust after idleing for 5-10 min, or coming to a stop at a light, so i yanked the DP and looked into the turbo and saw wetness just past the turbine wheel i also have some shaft play! So its back to stock and at the dealer...
Anybody else STG2 notice this?
You may be experiencing exactly why there was a recall on the oil feed line. They should honor the warranty and get a new turbo for you if all works well.
Good luck
already had the line checked and braket installed. its smoking out of the rear not from under the hood....
I dropped the car off today.
yeah probably a seal :(
hope they cover it with your aftermarket downpipe
EDIT: nm I saw you went back to stock... good luck either way
Typical! No problem found...
i said so am i just imagining the smoke coming from my car?
Gonna stay stock for a couple days see if it repeats again.
Were/Are you able to reach the "wetness" to determine what exactly the liquid is? That is, have you verified it is in fact oil?
Nah i cant get to it... im just gonna wait till it gets worse...
Drove for an hour today and it never smoked!
I personally wouldn't wait as you said earlier, you have bearing play already. @stage 2, you may have been boosting past the turbos limitations, busted or damaged the seal and bearing.
1 - 10 of 10 Posts
