1 - 20 of 51 Posts
I have an 08 Rex sedan that is stock w only 28k miles. I hate the OEM exhaust, doesn't even sound or feel like a subie.
So as far as catbacks, for sound and boost I've read threads for Invidia and Perrin.
Honestly I haven't found a pro/con that out weighs either one. Or if anyone can suggest a cb I'm open to ideas.
There are many exhaust options out there, do some searching around a bit and take a look at the different vendors sites to see what you would like. Youtube will help for sound, but the catback is not going impact your boost at all. Its really not going to do anything other than change the sound.
Magnaflow SS.I put this exhaust on 2 yrs.ago no rust, welds are perfect, and sounds great! Shop around for best price.Good Luck!
At what point or part when do you start changing the exhaust all the back to the headers do you lose the subie sound? Is it possible to mod and increase boost and retain sound?
Any power loss or gains? Is a catback mainly for sound?
Do u want loudness. And awesome rumble. Or mild sound with more mild rumble. I have the tusedo exhaust. I love it. It's a invidia knockoff.
Plus its cheap.
Since the catback is pretty much just for the sound, I would suggest scouring Youtube. There is an exhaust note video for every brand imaginable.
Not obnoxious loud but at least the typical signature low rumble scubby sound. Just curious when you start changing out more pipes like the up or dp does that sound drastically change when you start increasing performance?
Ya been trying to compare even though I'm sure there is major difference in person. Thank You!! :))
No it does not.
you might be able to find a SPT exhaust as a take off from someones car. I have one on my 09 hatchback and I think it is perfect. I am running stage 2+ and the exhaust is quite around town, but when you get on it in the open road the exhaust sounds throuty and like a Subaru should sound. My $0.02
.02
You still get the low rumble and scubby sound even from the spt? How's it sound ideling? Or around 2500rpm?
Youtube really has pretty much everything on there and there are some nice videos. You will make more power with a proper tune and downpipe (don't do a downpipe without a tune). You can do a stage 1 tune but that doesn't require a cat back but will net you some more power and you can add an intake, etc. You will only change the rumble sound if you go to equal length headers otherwise it may change the tone a bit but not the rumble itself.
Discussion Starter #15
That's great info! My burning question is where do I start? Do I look into a cte or just start by changing out the downpipe first then stage 1 tune?
It depends how much you want too spend really as far as just catback or downpipe as well. Start by looking on one of the vendors websites and listening on YouTube to the different exhausts they have for sale. There are also the Ebay exhausts out there too.
You would use a stage 2 tune for a downpipe and stage 1 for catback.
Discussion Starter #17
Which is recommended, stage 2 then down pipe or dp then stage 2?
You have to do the downpipe and stage 2 tune at the same time. If you have a cobb AP you can run their base stage 2 map that comes with the AP and upgrade to a better off the shelf stage 2 tune or get a custom tune for you mods if you add anything else (like a intake, intercooler, ebcs, etc.).
  • Like
Reactions: Hoonigan808
That's awesome info thanks!
Is it worth doing a Cobb stage 1 before using catbacks?
1 - 20 of 51 Posts
