1 - 15 of 15 Posts
I am gonna change my timing belt and I just wanted to know what I should also change with it... I have vacation all week so I really don't need my car but I wanna do all the maintence all at once if I'm gonna have everything apart... I have 93k on my car... I also need to do my ps belt
I would do both the PS and A/C belts (Keep in mind the A/C belt is a stretch type and needs to be cut off due to there being no tensioner), T-belt, water pump, tensioner and idlers, and the cam seals wouldn't be too bad of an idea.
Yeah I got this list of a guy doing it off a 02 wrx
The previous list:
timing belt 13028AA240
tensioner 13033AA042
idlers
rh side upper 13073AA142
rh side lower 13073AA142
lh cogged 13085AA080
lh lower 13073AA200
Water pump 21111AA026
gasket 21114AA051
+ I would recommend
thermostat and gasket + cam seals + oil pump o'ring + front crank seal
So I'm gonna get
gates racing kit
tckwp328rbsf
Ps belt
K050345R
Mishimoto thermostat
Oem cam, crank seals and o'ring...
Most people say stick with OEM Thermostats, it's such a trivial thing for aftermarkets to mess up at.
I was thinking that... But I plan on doing a motor build and trying to make a straight drag car and I didn't wanna have to replace this later
Is it necessary to change the oil pump o ring and the cam and crank seals? I can't find a how to on those either
AC belt you can walk off and on, but it's miserable.
I found a pretty easy method of working the AC belt off the pulley:
Feed a piece of flexible tubing/hose in between the belt and the ribbed pulley as you rotate the crank clockwise. As the tubing is drawn into the pulley, it squishes & lifts the belt out of the grooves so you can push it off by hand or with a pry bar of some kind.
1 - 15 of 15 Posts
